> I gather with linux, the network stack will only
> deliver an incoming (pv search) broadcast UDP packet to one of those
> processes.
You will see a warning message about the issue when you start the 2nd IOC.
As a workaround, a unicast (a single host IP) in the EPICS_CA_ADDR_LIST will
connect.
PS: The new multicasting support will provide a nice solution for this
issue.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Claude Saunders
> Sent: Tuesday, May 17, 2011 8:02 AM
> To: [email protected]
> Subject: Re: Channel Access not connecting
> Hi Bruce,
> From your first sentence, I see "IOC's" (plural) and "linux". I
> recently had what I believe is the same problem, which Andrew Johnson
> kindly helped me understand. If you are running two iocs on one linux
> host, using default ports, you wind up with two processes listening on
> the same udp port. I gather with linux, the network stack will only
> processes. If it happens to be the one without the PV you're looking
> for, then the ca_search fails, even though the other IOC process
> contains the PV.
> - Claude
> On 05/17/2011 12:12 AM, Bruce Hill wrote:
> > I've been having trouble with one linux machine where my IOC's appear
> > to be running correctly, dbgf works from iocsh, but caget from another
> > window on the same machine fails to connect. I suspect it has
> > something
> > to do with how the multiple interfaces on this machine are configured,
> > but
> > so far have been unable to find a solution.
> > # ifconfig
> > eth0 Link encap:Ethernet HWaddr 00:1E:68:79:5C:4E inet
> > addr:134.79.32.161 Bcast:134.79.35.255 Mask:255.255.252.0
> > inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
> > UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
> > RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
> > TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
> > collisions:0 txqueuelen:1000
> > RX bytes:18427912 (17.5 MiB) TX bytes:9772031 (9.3 MiB)
> > Interrupt:19
> > eth2 Link encap:Ethernet HWaddr 00:1E:68:79:5C:50 inet
> > addr:192.168.254.2 Bcast:192.168.254.255 Mask:255.255.255.0
> > inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
> > RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
> > TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
> > RX bytes:80539799 (76.8 MiB) TX bytes:64420869 (61.4 MiB)
> > Interrupt:20 Base address:0x4000
> > Gateway is 134.79.35.1
> > I'm running with defaults for the EPICS_CA* and EPICS_CAS* env
> variables,
> > but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
> > and EPICS_CA_INTF_ADDR_LIST with no success.
> > See attached files for casr, epicsEnvShow, ifconfig, and netstat output
> > for more configuration details. We're running base 3.14.9
> > everywhere, but this
> > is the only machine showing this problem.
> > The casr output includes:
> > UDP Server:
> > UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
> > This looks wrong to me, as my working IOC's show a valid UDP addr, but
> > I'm
> > not sure how to fix this, or even if this is the root problem.
> > Any suggestions would be appreciated.
> > Thanks,
> > - Bruce
> > P.S. When I run caget, tcpdump shows:
> > # /usr/sbin/tcpdump -i eth0 -n -nn udp dst portrange 5064-5065
> > tcpdump: verbose output suppressed, use -v or -vv for full protocol
> > decode
> > listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
> > 21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP,
> > length 16
> > 21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> Claude Saunders<[email protected]>
> Software Services Group Leader
> Advanced Photon Source, Argonne National Laboratory
> Argonne, IL 60439 630 - 252 - 6619
> We write suggestions, suggesting fading to silence
> And that must please you
> My mirror's tarnished with 'no help'
> - Gary Numan
- Channel Access not connecting Bruce Hill
- Re: Channel Access not connecting Claude Saunders
TCP_NODELAY option set failed Michael Davidsaver
RE: Channel Access not connecting Jeff Hill
<2011>
Re: Channel Access not connecting Bruce Hill
<2011>
