Subject: |
areaDetector Prosilica IOCs on Windows 7? |
"Mark Rivers" <[email protected]> |
To: |
"EPICS Tech Talk" <[email protected]> |
Date: |
Wed, 27 Apr 2011 10:39:16 -0500 |
Folks,
I am having problems running areaDetector with the Prosilica driver
under Windows 7.
The same exectuable works fine on XP SP3:
- If the Prosilica filter driver (V 1.20) is disabled it works fine
(though uses more CPU)
- If the filter driver is enabled it also works fine.
In both cases when I exit the IOC application all is well.
On Windows 7 I observe the following:
- If the filter driver is disabled I can talk to the camera. However,
when I try to acquire frames, no frames are acquired. I can exit the
IOC fine.
- If the filter driver is enabled then I can talk to the camera fine,
and I can acquire frames fine. However, when I exit the IOC, either by
typing "exit" or by closing the window, I get a BLUE SCREEN! This
happens every time.
Has anyone else tried to run the Prosilica IOC under Windows 7?
- RE: areaDetector Prosilica IOCs on Windows 7? Mark Rivers
Large number of sequencers running per soft IOC under Linux: Kernel becomes unresponsive Ernest L. Williams Jr.
devIocStats Displays Martin L. Smith
<2011>
<2011>
