On 09:31 Tue 22 Mar , Andrew Rhyder wrote:
> There is not much wrong with your code below, but I believe you always need to create widgets like QLabels (our EPICS flavor or otherwise) within a main window widget.
No need of main window
or layout
or "how to use Qt" book. ;-)
> Also, the CA connection is not established automatically, you have to call the 'activate()' method once the widget is created.
Ok, that was the missing part
#include <QApplication>
#include <QCaLabel.h>
int main(int argc, char *argv[])
QApplication a(argc, argv);
QCaLabel label("DMC2183:1:DscrptnSI");
label.activate();
label.show();
return a.exec();
> Calling 'activate()' is a minor overhead that I would like to avoid for simple widgets that could otherwise just 'go' but allows for widgets that take multiple PVs and then require macro substitution to be applied to those PVs.
I love the ASgui utility
The documentation is quite good to get you started (once you find and read it ;)
I would love to see more advanced widgets.
Overall this ca_framework is...
... awesome!
Emmanuel
- RE: epicsqt first try Andrew Rhyder
- epicsqt first try emmanuel_mayssat
PyEpics 3.1.0 Matt Newville
GPIB DCL Robert Emery
<2011>
<2011>
