1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: epicsqt first try
To: EPICS tech-talk <[email protected]>
Date: Mon, 21 Mar 2011 14:45:30 -0700
----- Forwarded message from [email protected] -----
Date: Wed, 16 Mar 2011 17:26:16 -0700
To: "Andrew Rhyder (epicsqt)" <[email protected]>,
Cc: Emmanuel Mayssat <[email protected]>
Andrew Rhyder,
I am testing your epicsqt package.
I may be interested in wrapping it in SIP so that your libraries can
be used in python (which i use heavily)
But before I do so, I am trying to test your Qt designer plugin.
First, I would like to use a simple QCaLabel object.
$ cat main.cpp
#include <QApplication>
#include <QCaLabel.h>
int main(int argc, char *argv[])
  QApplication a(argc, argv);
  QCaLabel label("DMC2183:1:DscrptnSI");
  label.show();
  return a.exec();
I have
$ caget DMC2183:1:DscrptnSI
DMC2183:1:DscrptnSI            OC:C50-C70-C90
I compile without any errors....
I start the program...
and I don't see anything ;-(
I assume that QCaLabel can be used to display the content of a string PV.  What am I doing wrong?
Emmanuel
----- End forwarded message -----
Emmanuel
RE: epicsqt first try Andrew Rhyder
Prev: RE: Breakpoint Table Error Steiner, Mathias
Next: RE: epicsqt first try Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Python with EPICS [was Re: epicsqt first try] Angus Gratton
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
