1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Autosave config file
To: Abadie Lana <[email protected]>
Cc: [email protected]
Date: Wed, 16 Mar 2011 07:59:52 -0500 (CDT)
----- Original Message -----
> From: "Abadie Lana" <[email protected]>
> To: [email protected]
> Sent: Wednesday, March 16, 2011 6:20:25 AM
> Subject: Autosave config file
> Hi all
> I would like to know if somebody can help me with autosave utility.
> I have a few questions:
> 1. in the xxxsaveRestore.cmd
> There is the function save_restoreSet_status_prefix : what is the use
> of this function since we specify the value of the prefix when calling
> dbLoadRecords and assigning the proper value to the macro
Autosave is partly a channel access client, and the
> I tried to out two different values as shown below. The only
> differences between the two is when I start the ioc, it complains that
> it could not read status value:
> epics> save_restore: Can't connect to all status PV(s)
> save_restore: Can't connect to status PV(s) for list 'plc-sample.sav'
> ### save_restore setup
> # status-PV prefix
> save_restoreSet_status_prefix("blabla:")
> # Use status-PV
> save_restoreSet_UseStatusPVs(1)
> # Debug-output level
> save_restoreSet_Debug(0)
> # Ok to save/restore save sets with missing values (no CA connection
> to PV)?
> save_restoreSet_IncompleteSetsOk(1)
> # Save dated backup files?
> save_restoreSet_DatedBackupFiles(1)
> # Number of sequenced backup files to write
> save_restoreSet_NumSeqFiles(3)
> # Time interval between sequenced backups
> save_restoreSet_SeqPeriodInSeconds(300)
> # specify where save files should be
> set_savefile_path("$(EPICS_AUTOSAVE_VAR)")
> # specify what save files should be restored. Note these files must be
> # in the directory specified in set_savefile_path(), or, if that
> function
> # has not been called, from the directory current when iocInit is
> invoked
> # Save files associated with the request files 'auto-output.req' and
> # 'auto-input.req'. These files are the standard way to use autosave
> set_pass1_restoreFile("plc-sample.sav")
> # specify directories in which to to search for included request files
> set_requestfile_path("./")
> dbLoadRecords("$(EPICS_MODULES)/autosave/db/save_restoreStatus.db"),
> "P=TEST-S7-COMM:")
> However the PVs related to autosave are there and autosave is working.
> So where i can see the impact?
> 2. I would like to check if i understood the policy for autosave
> generated files - the configuration used is the previous one
> - We have xxx.sav_<date> which says the initial values used when the
> ioc started :
> - Then it replicates this file to a savX (circular algorithm between
> .sav, .sav0, sav1)
> - .sav has always a backup .savB and copied to .sav sav0 or sav1 every
> 5mn
> - we also use
> create_monitor_set("plc-sample.req",30,"P=TEST-S7-COMM:") ->if a PV
> changes its value then it will be report on .sav or the most recent
> one? As i think .sav is the one used for restore
> [root@current ~]# ll /var/opt/codac-2.0/autosave/ |grep
> plc-sample|grep 'Mar 16'
> -rw-r--r-- 1 codac codac 392 Mar 16 11:58 plc-sample.sav
> -rw-r--r-- 1 codac codac 392 Mar 16 11:57 plc-sample.sav0
> -rw-r--r-- 1 codac codac 392 Mar 16 12:02 plc-sample.sav1
> -rw-r--r-- 1 codac codac 392 Mar 16 10:53 plc-sample.sav_110316-105306
> -rw-r--r-- 1 codac codac 392 Mar 16 11:02 plc-sample.sav_110316-110228
> -rw-r--r-- 1 codac codac 392 Mar 16 11:57 plc-sample.sav_110316-115743
> -rw-r--r-- 1 codac codac 392 Mar 16 11:52 plc-sample.sav2
> -rw-r--r-- 1 codac codac 392 Mar 16 11:58 plc-sample.savB
> [root@current ~]#
> root@current ~]# ll /var/opt/codac-2.0/autosave/ |grep plc-sample|grep
> 'Mar 16'
> -rw-r--r-- 1 codac codac 371 Mar 16 12:05 plc-sample.sav
> -rw-r--r-- 1 codac codac 371 Mar 16 12:12 plc-sample.sav0
> -rw-r--r-- 1 codac codac 371 Mar 16 12:07 plc-sample.sav2
> -rw-r--r-- 1 codac codac 371 Mar 16 12:05 plc-sample.savB
> [root@current ~]#
> Many thanks for your feedback and hope I'm clear
> Lana
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
RE: Autosave config file Abadie Lana
Prev: KEK/J-PARC after the eatrhquake on March11 上窪田@KEKTokai
Next: RE: Autosave config file Abadie Lana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Autosave config file Kasemir, Kay
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
