John/Dirk,
does StreamDevice/ASYN have or allow a custom read function
like drvAscii does? I have one for our dust monitor that turns
3 lines of reply (which are spaced out in time) and way too
long for drvAscii into something that is one line of less than
80 characters.
Wondering,
Maren
John Dobbins wrote:
Dirk,
As it turns out this device really is sending one character per network
packet. The device is a new version of the Gamma/Digitel Small Pump
Controller which has an optional ethernet interface. The ethernet
interface has other problems, e.g. one can crash the controller (turning
of the pump H.V.) by overloading it with data requests. Gamma tells me
they are working on improving the ethernet interface. For now I as using
the RS-232 interface for this device which operates without problem.
John Dobbins
On 2/2/2011 10:30 AM, Dirk Zimoch wrote:
Hi John,
StreamDevice normally reads first a single byte and then the rest in
chunks of up to 63 bytes. The reason is that the first byte uses a
different timeout (ReplyTimeout) than the others (ReadTimeout). The rest
is fetched in 63 bytes chunks because I use an internal buffer of 64
bytes and want to be able to add a null byte at the end to avoid
problems with some debug output.
So the first "read 1" is normal. What surprises me are the other lines.
When you switch on debugging in StreamDevice (var streamDebug 1), what
do you see?
Dirk
John Dobbins wrote:
Dear All,
I am connecting to a Gamma Vacuum SPCe ion pump power supply. This
device has an ethernet port which accepts telnet connections.
I set up StremDevice to communicate with it on port 23,
I have asyn Trace Masks set as follows:
asynSetTraceMask("SPCe",-1,0x09)
asynSetTraceIOMask("SPCe",-1,0x2
I have a problem in that the response string , which I expect to look
like "OK 00 7.90E-13 TORR"
appears like this:
epics> 2011/01/17 16:14:55.995 172.18.32.21:23 write 7
spc 0B\r
2011/01/17 16:14:56.475 172.18.32.21:23 read 1
O
K
0
0
2011/01/17 16:14:56.476 172.18.32.21:23 read 1
7
9
2011/01/17 16:14:56.477 172.18.32.21:23 read 1
0
E
1
2011/01/17 16:14:56.478 172.18.32.21:23 read 1
3
T
O
R
2011/01/17 16:14:56.479 172.18.32.21:23 read 1
R
\r
Can someone tell me what is going on here?
Regards and thanks,
John Dobbins
Cornell University
Lab for Elementary Particle Physics
- Re: StreamDevice/ASYN connection to a Telnet port Dirk Zimoch
- StreamDevice/ASYN connection to a Telnet port John Dobbins
- Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
Re: epics 3.14.12 and readline 5.1 Matt Rippa
calc doesn't appear to be working with MEDM for string expressions (Win32 Extension Version 1.40) Jay Steele
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
