Yes, in my case it should be "read*next*line". ;)
This works. Thanks.
On 02/02/2011 09:57 AM, Eric Norum wrote:
> You need to link agains the ncurses library too.
> In CONFIG_SITE.Common.linux-x86 (or CONFIG_SITE.Common.linux-x86_64 as appropriate) uncomment the line that gets NCURSES:
> # No other libraries needed (recent Fedora, Ubuntu etc.):
> #COMMANDLINE_LIBRARY = READLINE
> # Needs -lncurses (RHEL 5 etc.):
> COMMANDLINE_LIBRARY = READLINE_NCURSES
> # Needs -lcurses (older versions)
> #COMMANDLINE_LIBRARY = READLINE_CURSES
> On Feb 2, 2011, at 11:48 AM, Matt Rippa wrote:
>> Hi Folks,
>> Sorry if this has come up before. I couldn't find anything
>> searching tech-talk. I'm trying to build epics-base 3.14.12 on
>> RHEL5. The build fails when I enable
>> COMMANDLINE_LIBRARY=READLINE in
>> configure/os/CONFIG_SITE.Common.linux-x86. The build works fine
>> when I comment this line out.
>> $ rpm -q readline
>> readline-5.1-3.el5
>> $ rpm -q readline-devel
>> readline-devel-5.1-3.el5
>> $ uname
>> Linux hbfcon03.hi.gemini.edu 2.6.18-194.el5PAE #1 SMP Tue Mar 16
>> 22:00:21 EDT 2010 i686 i686 i386 GNU/Linux
>> FWIW, this compiles with readline just fine on my f13 laptop: ($
>> rpm -q readline readline-6.1-2.fc13.i686).
>> Thanks,
>> Matt Rippa
>> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>> -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE
>> -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -MMD -I.
>> -I../O.Common -I. -I.. -I../../../../include/os/Linux
>> -I../../../../include ../warshall.c
>> /usr/bin/g++ -o antelope
>> -L/export/home/software/base-3.14.12-new/lib/linux-x86
>> -Wl,-rpath,/export/home/software/base-3.14.12-new/lib/linux-x86
>> -m32 closure.o error.o lalr.o lr0.o main.o
>> mkpar.o output.o reader.o skeleton.o symtab.o verbose.o
>> warshall.o -lCom
>> /usr/lib/libreadline.so.5: undefined reference to `PC'
>> /usr/lib/libreadline.so.5: undefined reference to `tgetflag'
>> /usr/lib/libreadline.so.5: undefined reference to `tgetent'
>> /usr/lib/libreadline.so.5: undefined reference to `UP'
>> /usr/lib/libreadline.so.5: undefined reference to `tputs'
>> /usr/lib/libreadline.so.5: undefined reference to `tgoto'
>> /usr/lib/libreadline.so.5: undefined reference to `tgetnum'
>> /usr/lib/libreadline.so.5: undefined reference to `BC'
>> /usr/lib/libreadline.so.5: undefined reference to `tgetstr'
>> collect2: ld returned 1 exit status
>> make[4]: *** [antelope] Error 1
>> make[4]: Leaving directory
>> `/export/home/software/base-3.14.12-new/src/toolsComm/antelope/O.linux-x86'
>> make[3]: *** [install.linux-x86] Error 2
>> make[3]: Leaving directory
>> `/export/home/software/base-3.14.12-new/src/toolsComm/antelope'
>> make[2]: *** [antelope.install] Error 2
>> make[2]: Leaving directory
>> `/export/home/software/base-3.14.12-new/src/toolsComm'
>> make[1]: *** [toolsComm.install] Error 2
>> make[1]: Leaving directory
>> `/export/home/software/base-3.14.12-new/src'
>> make: *** [src.install] Error 2
- epics 3.14.12 and readline 5.1 Matt Rippa
- Re: epics 3.14.12 and readline 5.1 Eric Norum
Re: StreamDevice/ASYN connection to a Telnet port Maren Purves
<2011>
calc doesn't appear to be working with MEDM for string expressions (Win32 Extension Version 1.40) Jay Steele
<2011>
