Hi Andrew,
I looked at using the select record but it only had 12 links and I have more possibilities but maybe I can still
Use it. Thanks!
- Kristi
-----Original Message-----
Sent: Wednesday, January 19, 2011 2:04 PM
To: [email protected]
Cc: Luchini, Kristi L.
Subject: Re: Changing DOL field from a subroutine record
Hi Kristi,
On Wednesday 19 January 2011 15:27:24 Luchini, Kristi L. wrote:
> I can do dbpf() from the console port to change a DOL field, so is there a
> reason why dbPutLink can't or am I just using this incorrectly? Any
> suggestions?
You can't change a link field using a database link (I'm not quite sure why we
don't allow that but it's probably because of the locking needed), but you can
do it with a CA link, so try adding the CA flag to your genSub OUTx field.
Note that changing links is not a fast operation though, in some cases putting
a selRecord in front of your DOL link instead might make more sense.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Changing DOL field from a subroutine record Luchini, Kristi L.
- Re: Changing DOL field from a subroutine record Andrew Johnson
Loading EPICS/RTEMS Apps from local filesystem on VME board Jim Eastman
<2011>
debian repository key change Davidsaver, Michael
<2011>
