1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: PV Mapping Using Java Annotations
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 11 Jan 2011 10:42:44 -0600
 Hi Lewis,
The reason I wanted to use annotations is so that I could use AOP to instrument my classes intead with CA code intead of repeatedly writing it for each PV backed object. For example, if you wanted to implement a callback that would be executed when an PV monitor fired you would typically do the following in JCA/CAJ.
1.  Create a context.
2.  Create a channel to the PV you want to monitor.
3. Create the monitor and map it to the java method you would like to callback to.
4.  Convert PV types to Java types when necessary.
5.  Execute pendIO calls when necessary.
6.  Write code to tear down the channel once you're done.
I feel like this is a manual process that could be automated for the majority of cases. If you just define the mapping of the callback method to the PV you are monitoring (with annotations in my case) you can use AOP to instrument your class with the rest of the code. The monitor case is almost identical to a Message Driven Bean/POJO in the J2EE world except your using a PV name instead of a JMS destination name. I also like the fact that my Java abstractions are decoupled from the CA code, which makes things like JUnit testing much easier.
I'll definitely take a look at the project you pointed out.
Mitch
On 01/11/2011 09:40 AM, J. Lewis Muir wrote:
At a minimum, it would provide an EpicsPv
object and make it easy to get and set values, easy to register interest
in a value change, do blocking puts, and more.  I've written such an
implementation, but there are a lot of changes and improvements it needs
before I'd make it publicly available.
Re: PV Mapping Using Java Annotations J. Lewis Muir
PV Mapping Using Java Annotations Mitch McCuiston
Prev: RE: PV Mapping Using Java Annotations Carcassi, Gabriele
Next: Re: PV Mapping Using Java Annotations Mitch McCuiston
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: PV Mapping Using Java Annotations J. Lewis Muir
Next: Re: PV Mapping Using Java Annotations J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
