I've been thinking about implementing an annotation based mapping of
Java objects to PVs. I thought I would ask the community if something
like this already exists before I take it on. If it doesn't exist,
would anyone find value in this. The idea is loosely based on how
Hibernate maps Java objects to a relational database, although the
read/write semantics are a little different. Here is an example.
public class EpicsMotor{
//This will peform a synchronous GET of PV "DLLM" upon invocation
@PV(name="DLLM", accessType=PVAccessType.READ)
public double getLowerLimit(){
//This will establish a PV monitor for "DRBV" that will call the method
//below upon any change in "DRBV"
@PV(name="DRBV", accessType=PVAccessType.MONITOR)
public void setDialPosition(double position){
//Any call to this method will result in a synchronous PUT
//to the PV named "S".
@PV(name="S", accessType=PVAccessType.WRITE)
public void setSpeed(double position){
//This will create a monitor for PV named "RBV" that will call this
method
//upon any change in "RBV". In addition, any invocations of this
method will
//be intercepted and a synchronous PUT to PV "RBV" will occur.
@PV(name="RBV", accessType=PVAccessType.MONITOR_WRITE)
public void setPosition(double position){
This would allow someone to instrument an instance of the class above at
runtime and "connect" it to a set of PVs (given a prefix i.e.
"xxx:motor1."). I feel that this would have the following advantages
over writing raw JCA/CAJ.
1. This could increase read performance because the POJO essentially
becomes a PV cache.
2. This cuts down dramatically on the amount of channel managment code
that needs writing.
3. The little bit of channel management code that is written is
centralized and can be better tested.
4. This provides a nice way of abstracting a collection of PVs for
easier application development.
Thanks in advance for your help!
Mitch McCuiston
mmccuiston@aps.anl.gov
- Re: PV Mapping Using Java Annotations J. Lewis Muir
- RE: PV Mapping Using Java Annotations Carcassi, Gabriele
RE: JAI CM-140GE Szalata, Zenon M.
RE: Writing mbbo/mbbi text labels using asynPortDriver/areaDetector Mark Rivers
<2011>
RE: 24-bit DAC matthew.pearson
<2011>
