All,
Sometime back I mentioned that LANSCE was experiencing a crash
in the Allen Bradley TCP/IP PLC driver (devEtherIP). There were some
maintenance days this week, and I found some time to track down the
cause. Apparently the following race condition is occurring.
o iocInit begins
o device support initialization functions start the drvEtherIP
auxiliary threads (one for each plc)
o when a network message comes back from the plc the drvEtherIP
auxiliary thread calls functions in devEtherIP which call scanOnce.
o scanOnce tries to use the uninitialized "onceQ" ring buffer,
and crashes.
o later, iocInit calls initOnce
o initOnce creates the "onceQ" ring buffer
We are experience the bug in R3.13, but looking at the latest
sourceforge sources I am inclined to suspect that there is also
a race condition vulnerability when the latest runs under R3.14.
Below are the patches I made to the driver. Unfortunately, it was
necessary to create two versions; one for R3.13 and one for R3.14.
We only run this driver on R3.13 IOC's so I have _not_ tested the R3.14
version of the fix; Furthermore, the authors of this driver should
review my fix as they may arrive at a better alternative.
Index: devEtherIP.c
RCS file: /epics/cvs/extensions/ab5550/dev/devEtherIP.c,v
retrieving revision 1.8
diff -r1.8 devEtherIP.c
286a287,302
> static void etherIP_scanOnce ( void * pRec )
> * astonished to discover that initHookRegister is in
> * initHooks.h in R3.13, but initHookRegister isnt
> * in iocCore object file in R3.13, so we resort
> * to an archaic brute force approach
> # ifndef HAVE_314_API
> while ( ! interruptAccept ) {
> epicsThreadSleep ( 0.1 );
> # endif
> scanOnce ( pRec );
417c433
< scanOnce(rec);
> etherIP_scanOnce ( rec );
469c485
< scanOnce(rec);
539c555
< scanOnce (rec);
589c605
< scanOnce(rec);
Index: drvEtherIP.c
RCS file: /epics/cvs/extensions/ab5550/dev/drvEtherIP.c,v
retrieving revision 1.6
diff -r1.6 drvEtherIP.c
25a26,27
> #include "initHooks.h"
1295a1298,1301
> #ifdef HAVE_314_API
> static int databaseIsReady = false;
> #endif
1308a1315,1320
> #ifdef HAVE_314_API
> if (!databaseIsReady) {
> epicsMutexUnlock(drvEtherIP_private.lock);
> return 0;
> #endif
1388a1401,1430
> #ifdef HAVE_314_API
> void drvEtherIP_initHook ( initHookState state )
> if (drvEtherIP_private.lock == 0) return;
> if ( state == initHookAfterScanInit ) {
> epicsMutexLock(drvEtherIP_private.lock);
> databaseIsReady = true;
> drvEtherIP_restart();
> #endif
> long drvEtherIP_drvInit ()
> * in initHooks.h in R3.13, but not in iocCore
> * object file in R3.13
> #ifdef HAVE_314_API
> int status = initHookRegister ( drvEtherIP_initHook );
> if ( status ) {
> errlogPrintf (
> "drvEtherIP_drvInit: init hook install failed\n" );
> #endif
> return 0;
1394c1436
< long (* inie) ();
> long (* init) ();
1399c1441
< NULL
> drvEtherIP_drvInit
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
- Re: devEtherIP Kasemir, Kay
Re: 64-bit ioc mca issue Tim Mooney
RE: 64-bit ioc mca issue Mark Rivers
<2010>
<2010>
