Hello
I have a problem in streamDevice2.
I use the streamDevice to control a VME monitor. As the example in
streamApp,I have three files: vme.cmd,
vme.db,vme.proto.These are parts of them:
vme.cmd
!./streamApp
dbLoadDatabase "O.Common/streamApp.dbd"
streamApp_registerRecordDeviceDriver
#where can protocols be located?
epicsEnvSet "STREAM_PROTOCOL_PATH", ".:protocols:../protocols/"
#setup the busses
#example serial port setup
drvAsynSerialPortConfigure "COM1", "/dev/ttyS0"
asynOctetSetInputEos "COM1",0,"\r\n"
asynOctetSetOutputEos "COM1",0,"\r\n"
asynSetOption ("COM1", 0, "baud", "9600")
asynSetOption ("COM1", 0, "bits", "8")
asynSetOption ("COM1", 0, "parity", "none")
asynSetOption ("COM1", 0, "stop", "1")
asynSetOption ("COM1", 0, "clocal", "Y")
asynSetOption ("COM1", 0, "crtscts", "N")
dbLoadRecords "vme.db","PREFIX=VME"
#dbLoadRecords "scalcout.db","PREFIX=DZ"
iocInit
#enable debug output
var streamDebug 1
vme.db
record(stringin, "$(PREFIX):T2") {
field(DTYP, "stream")
field(INP, "@vme1.proto spyT2 COM1")
field (SCAN, "I/O Intr")
record(stringin, "$(PREFIX):T3") {
field(INP, "@vme1.proto spyT3 COM1")
vme.proto
Terminator =" ";
ReplyTimeout = 10000; # 10 sec is very long, for keyboard input
ReadTimeout = 2500; # also long for keyboard input
spyT2{
in "T2:%2c";
spyT3 {
in "T3:%2c";
Last month,it works well, I can get the value from the VME monitor
with it.
Recently,I install CSS_EPICS_2.3.0-boy, I want to desire a manager
display for it.
But the problem happened.This is the error :
iocInit
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Aug 19 2010
2010/10/29 10:15:03.397 _main_ VME:HA: Wrong link type CONSTANT
2010/10/29 10:15:03.398 _main_ VME:HA: Record initialization failed
2010/10/29 10:15:03.398 _main_ VME:S1: Wrong link type CONSTANT
2010/10/29 10:15:03.398 _main_ VME:S1: Record initialization failed
2010/10/29 10:15:03.399 _main_ VME:HA: No businterface attached
2010/10/29 10:15:03.399 _main_ VME:HA: Can't start "I/O Intr" protocol
2010/10/29 10:15:03.399 _main_ VME:S1: No businterface attached
2010/10/29 10:15:03.399 _main_ VME:S1: Can't start "I/O Intr" protocol
It works bad ,I don't know why this happen.I run
"example.cmd","test.cmd",they have the
same problem.Interesting,only "stringin" record performs error,others
run well.
Please help me,looking forward to your reply.
Yiming
