1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on ARM (continued)
To: [email protected]
Date: Wed, 27 Oct 2010 13:56:38 -0500
On Wednesday 27 October 2010 13:31:00 [email protected] wrote:
> > In src/catools/Makefile you find:
> > LIBRARY_HOST += catools
> > PROD_HOST += caget camonitor cainfo caput
> > This builds caget etc only for the host, not for the cross targets.
> > To build the tools for all cross Linux IOCs, you may try to add:
> > LIBRARY_IOC_Linux += catools
> > PROD_IOC_Linux += caget camonitor cainfo caput
> I didn't try the above. But I found I simply needed
> VALID_BUILDS += Host
> in my CONFIG_SITE.Common.linux-arm4vtl
> In linux-arm, we already have
> VALID_BUILDS = Ioc (which basically means build the libs)
True, although that will also cause all of the host tools to be built and
installed as well; not really a problem, but it will slow up your builds a
bit.  Dirk's instructions should also work, but they do result in some benign
warnings from the build system.
I've made a change for 3.14.12 which will build the catools for all
architectures except vxWorks and RTEMS.
It would be nice it these tools could be included in an IOC image and register
themselves with the iocsh (a long time ago there were such CA commands in the
vxWorks IOC), but that's probably a fair bit of work to do properly â Ralph,
one for the Codeathon wish-list maybe?
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: EPICS on ARM (continued) Rod Nussbaumer
RE: Thread model for EPICS on ARM CPU michael.abbott
Re: EPICS on ARM (continued) Dirk Zimoch
Re: EPICS on ARM (continued) emmanuel_mayssat
Prev: Re: EPICS on ARM (continued) emmanuel_mayssat
Next: RE: EPICS CA problems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS on ARM (continued) Rod Nussbaumer
ANJ, 27 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
