1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Linux libraries for areaDetector
Date: Tue, 5 Oct 2010 16:55:40 -0700
I did a package check on our diskless headless server image based on RHEL5
and found all the packages were already installed.   Our image isn't stripped
down to any extent, so this may not be true for other headless servers.
- Bruce
P.S.   You can query the package names for the needed libraries with:
yum info freetype libgomp libX11 libXext bzip2 lcms libpng libxml2  fontconfig
[email protected] wrote:
freetype gomp X11 Xext bz2 lcms png12 xml2 fontconfig
I just tested a statically built version of the simDetector
on a Linux system (marCCD) to which I had added no additional
libraries, and it worked.  This means that the above
libraries were indeed available as system libraries.
Can anyone comment on whether it is "safe" to count on the
above libraries being available on "most" Linux systems?
Hi
I'm using the rather conservative RHEL5 and those are all present. I
suspect that any Gnome desktop system will have them installed. They
won't all be present on a headless server install.
James
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Linux libraries for areaDetector Mark Rivers
RE: Linux libraries for areaDetector james.rowland
Prev: Re: Linux libraries for areaDetector Ralph Lange
Next: Equipment with EPICS support tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Linux libraries for areaDetector Kate Feng
ANJ, 09 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
