Well Mark,
Peter Zumbruch posted the same error some time ago on 28th of June (subject: No PLT for relocation)
At that time nobody responded ...
We also still have no solution, it seems to be a linker problem with the cris-gnu stuff.
Burkhard
Am 30.09.2010 um 18:04 schrieb Mark Rivers:
> I have never seen an error like that.
> What type of system are you building for, an embedded IOC or a
> workstation?
> You are using asyn R4-10 which is quite old, and was tested with EPICS
> 3.14.8, but I don't think that is the problem. Could you be running out
> of memory on the target system?
> It did build the executables in the asyn test directories OK, right? So
> the linker can build executables, just not your IOC executable?
> Mark
> -----Original Message-----
> From: Florian Feldbauer [mailto:[email protected]]
> Sent: Thursday, September 30, 2010 10:29 AM
> To: Mark Rivers
> Cc: Florian Feldbauer; [email protected]
> Subject: RE: Cross compiling EPICS for cris v10
> Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
> still I can't build my IOC application
> /usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
> xis-linux-gnu/bin/ld:
> /usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
> basyn.a(devAsynInt32.o):
> No PLT for relocation R_CRIS_32_GOTPLT against symbol
> `epicsRingBytesCreate' from .text section
> final link failed: Bad value
> collect2: ld returned 1 exit status
> make[3]: *** [slowCtrl] Error 1
> make[3]: Leaving directory
> `/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
> make[2]: *** [install.linux-cris_v10] Error 2
> make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
> make: *** [slowCtrlApp.install] Error 2
> Florian
Dr. Burkhard Kolb
Pleikartsförster Str. 38
69124 Heidelberg
Germany
E-Mail: [email protected]
Tel: +49 6221 718640 / Fax: +49 6221 718641
- Re: Cross compiling EPICS for cris v10 Dirk Zimoch
- Cross compiling EPICS for cris v10 Florian Feldbauer
- RE: Cross compiling EPICS for cris v10 Mark Rivers
- RE: Cross compiling EPICS for cris v10 Florian Feldbauer
RE: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Jeff Hill
Channel Archiver overlapping blocks james.rowland
<2010>
Re: Cross compiling EPICS for cris v10 Matthieu Bec
<2010>
