1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cross compiling EPICS for cris v10
To: <[email protected]>
Date: Thu, 30 Sep 2010 12:37:31 -0400
a couple of times, I had the default optimize level create all kind of weird issues, those went away lowering the opt level or disabling it completely.
You can set that in your $(TOP)/configure/ files, consult the AppDev guide for their names and locations: OPT_CXXFLAGS_ etc
and recompile from scratch
make clean all
Matthieu
On 09/30/10 12:04, Mark Rivers wrote:
I have never seen an error like that.
What type of system are you building for, an embedded IOC or a
workstation?
You are using asyn R4-10 which is quite old, and was tested with EPICS
3.14.8, but I don't think that is the problem.  Could you be running out
of memory on the target system?
It did build the executables in the asyn test directories OK, right?  So
the linker can build executables, just not your IOC executable?
-----Original Message----- From: Florian Feldbauer [mailto:[email protected]] Sent: Thursday, September 30, 2010 10:29 AM To: Mark Rivers Cc: Florian Feldbauer; [email protected] Subject: RE: Cross compiling EPICS for cris v10
Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
still I can't build my IOC application
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld:
/usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
basyn.a(devAsynInt32.o):
No PLT for relocation R_CRIS_32_GOTPLT against symbol
`epicsRingBytesCreate' from .text section
final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory
`/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Mark Rivers
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Prev: Re: Cross compiling EPICS for cris v10 Tim Mooney
Next: Re: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Steven M. Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Cross compiling EPICS for cris v10 Andrew Johnson
Next: Re: Cross compiling EPICS for cris v10 Burkhard Kolb
ANJ, 30 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
