The directory where you copied the file is one which should be automatically searched. Thus, I think you should replace this line:
SYS_PROD_LIBS += $(TOP)/myappApp/lib/visa32
with
PROD_LIBS += visa32
Sent: Sun 9/5/2010 10:07 PM
To: tech-talk
Subject: Build IOC linking external *.lib file failed
Hi,All:
I am trying to setup a IOC example in tek DPO scope, which need to use the visa32.lib in this project, I copied visa32.lib
to $(top)/myAppapp/lib folder(top is the root of this example),and in makefile in src,I add the following line:
# ADD MACRO DEFINITIONS AFTER THIS LINE
and build failed, could you tell me how to do ?
Thank you
Tomas
2010.9.2
PS:my enveriment is : winXP, cygwin1.5, gcc, make 3.81, perl, base 3.14.11
and this is the result :
??@zn /cygdrive/c/testapp
$ make
make -C ./configure install
make[1]: Entering directory `/cygdrive/c/testapp/configure'
make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory `/cygdrive/c/testapp/configure/O.cygwin-x86'
perl /cygdrive/c/base-3.14.11/bin/cygwin-x86/convertRelease.pl checkRelease
make[2]: Leaving directory `/cygdrive/c/testapp/configure/O.cygwin-x86'
make[1]: Leaving directory `/cygdrive/c/testapp/configure'
make -C ./myappApp install
make[1]: Entering directory `/cygdrive/c/testapp/myappApp'
make -C ./src install
make[2]: Entering directory `/cygdrive/c/testapp/myappApp/src'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/testapp/myappApp/src/O.cygwin-x86'
perl /cygdrive/c/base-3.14.11/bin/cygwin-x86/makeIncludeDbd.pl base.dbd xxxSuppo
rt.dbd dbSubExample.dbd myappHello.dbd initTrace.dbd ../O.Common/myappInclude.db
d
Expanding dbd
/cygdrive/c/base-3.14.11/bin/cygwin-x86/dbExpand.exe -I . -I .. -I ../../../dbd
-I/cygdrive/c/base-3.14.11/dbd -o ../O.Common/myapp.dbd ../O.Common/myappInclud
e.dbd
Installing created dbd file ../../../dbd/myapp.dbd
g++ -o myappSupport.dll -shared -Wl,--out-implib,myappSupport.lib -Lc:/base-3.14
.11/lib/cygwin-x86 -m32 xxxRecord.o devXxxSoft.o dbSubExampl
e.o myappHello.o initTrace.o devWfSoft.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrs
rvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -l../
../../myappApp/lib/visa32 -lpthread -lreadline -lcurses -lm
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld: cannot find
-l../../../myappApp/lib/visa32
collect2: ld returned 1 exit status
make[3]: *** [myappSupport.dll] Error 1
make[3]: Leaving directory `/cygdrive/c/testapp/myappApp/src/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/testapp/myappApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/cygdrive/c/testapp/myappApp'
make: *** [myappApp.install] Error 2
Tomas
2010-9-2
- Build IOC linking external *.lib file failed zhangning2095
RE: Camera Link drivers for areaDetector? fajin.yuan
cPCI leige
<2010>
RE: Build IOC linking external *.lib file failed Mark Rivers
<2010>
