1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: BOY - XY Graph and macro substitution
To: PaweÅ PrÄdki <[email protected]>
Cc: TechTalk <[email protected]>
Date: Sat, 07 Aug 2010 18:44:52 -0400
Hello PaweÅ,
thanks a lot for your cooperation - I didn't want to discourage you from using tech-talk at all, but (as John Sinclair mentioned) a tracker entry supports the developers better in handling a possible bug.
If a bug is likely to affect other installations (especially for things that are widely used in production environments), an additional warning on tech-talk may in fact be very appropriate.
Thanks for using BOY and finding bugs!
Ralph
PaweÅ PrÄdki wrote:
Hello Ralph,
I wasn't aware of that, sorry. Also, I was not sure if it was a bug and I knew Xihui receives this newsletter regularly.
I will direct my possible further comments to the bug tracking system.
Cheers,
Pawel
On 06.08.2010 23:11, Ralph Lange wrote:
Hello PaweÅ,
please note there's also the CSS bug tracking system on SourceForge [1].
Entering bug reports there will make them easier to track and manage -
compared to threads in tech-talk.
Ralph
[1] https://sourceforge.net/apps/trac/cs-studio/report
On 06.08.2010 17:02, PaweÅ PrÄdki wrote:
Hi Xihui,
That's good to hear. I'm looking forward to the newest release. I hope
I don't find any more bugs but if I do I will let you know.
Cheers,
Pawel
On 06.08.2010 19:38, Chen, Xihui wrote:
Hi Pawel,
Yes, this is a bug. Every string property is supposed to support
macro replacement. I have fixed it now. It will be available in next
release version, probably in one month.
Thank you for finding and reporting it to me!
Xihui
-----Original Message-----
[mailto:[email protected]] On Behalf Of Pawel Predki
Sent: Friday, August 06, 2010 8:00 AM
To: TechTalk
Subject: BOY - XY Graph and macro substitution
Hello,
I've come across another problem with BOY. This time it concerns the
XY Graph widget.
It seems this widget does not substitute macros. The attached file
demonstrates this behavior. A Text Update, a Label and an XY Graph
widgets are included. For the first two, the $(amacro) text is
substituted but this does not happen for text fields in the XY Graph,
namely the Title and Axis Titles.
Is it a desired behavior or is it a bug?
Cheers,
Pawel Predki
BOY - XY Graph and macro substitution PaweÅ PrÄdki
RE: BOY - XY Graph and macro substitution Chen, Xihui
Re: BOY - XY Graph and macro substitution PaweÅ PrÄdki
Re: BOY - XY Graph and macro substitution Ralph Lange
Prev: RE: aiRecord/devGpib problem Allison, Stephanie
Next: Re: aiRecord/devGpib problem Andrew Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: BOY - XY Graph and macro substitution PaweÅ PrÄdki
Next: Looking for an experienced data acquisitoin architect Dalesio, Leo
