1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: linking to shared objects user libraries
To: [email protected]
Date: Fri, 09 Jul 2010 09:48:24 -0500
On 7/9/10 9:38 AM, Pierrick Hanlet wrote:
> Hi,
> I'm using 3.14.11 on a linux machine. I would like to use several
> external (i.e. non-EPICS) .so libraries in my ioc makefile/ However,
> the linking appears to default to static libraries. According to the
> applications developers guide, section 4.6.23.7, I should modify
> CONFIG_SITE, but this doesn't work.
> What should I do?
Hi, Pierrick.
Did you try setting both STATIC_BUILD=NO and SHARED_LIBRARIES=YES?
Also, check to make sure your IOC's configuration isn't changing those
variables.  If it is, you will need to remove or change them their too.
Lewis
Re: linking to shared objects user libraries J. Lewis Muir
Re: linking to shared objects user libraries Pierrick Hanlet
Prev: RE: linking to shared objects user libraries Mark Rivers
Next: iocStats (was: vxStats memory corruption) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: linking to shared objects user libraries J. Lewis Muir
