1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: linking to shared objects user libraries
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 09 Jul 2010 09:58:37 -0500
Thanks for the quick responses.
Yes, I did STATIC_BUILD=NO and SHARED_LIBRARIES=YES
in xxx/configure/CONFIG_SITE.
Where might these be overwritten?  Also, since I'm using a
mixture of static and shared object libraries, will this
configuration fix me to one type of library or another?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Friday, July 9, 2010 9:50 am
To: [email protected]
> On 7/9/10 9:38 AM, Pierrick Hanlet wrote:
> > Hi,
> > I'm using 3.14.11 on a linux machine. I would like to use several
> > external (i.e. non-EPICS) .so libraries in my ioc makefile/ However,
> > the linking appears to default to static libraries. According to the
> > applications developers guide, section 4.6.23.7, I should modify
> > CONFIG_SITE, but this doesn't work.
> > What should I do?
> Hi, Pierrick.
> Did you try setting both STATIC_BUILD=NO and SHARED_LIBRARIES=YES?
> Also, check to make sure your IOC's configuration isn't changing those
> variables.  If it is, you will need to remove or change them their too.
> Lewis
RE: linking to shared objects user libraries Mark Rivers
Re: linking to shared objects user libraries J. Lewis Muir
linking to shared objects user libraries Pierrick Hanlet
Prev: Re: linking to shared objects user libraries J. Lewis Muir
Next: RE: linking to shared objects user libraries Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
