1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SNMP and APC rack power distribution units
To: Elliott Wolin <[email protected]>
Cc: epics <[email protected]>
Date: Thu, 24 Jun 2010 09:35:36 -0400
Hi Elliot,
We use a different brand (pulizzi). At the time, I found about devSnmp but that only had read capabilities. In my case I needed to control the unit - from a vxWorks IOC.
The pulizzi come with secure http (not very friendly to implement), a serial port with intricate layers of menus (gave up on that), and snmp. I couldn't find any obvious snmp client for vxworks, so I ran a network sniffer, looked at how the packets were formed and wrote a simple udp socket client routine invoked from SNL. So far it has worked well.
Regards
Matthieu
On 06/24/10 09:06, Elliott Wolin wrote:
We're thinking of using APC Ethernet-controllable rack power
distribution units. One of the many ways you can talk to them is via SNMP.
Has anyone used these or similar units? And what is the status of EPICS
communicating via SNMP?
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
SNMP and APC rack power distribution units Elliott Wolin
Prev: RE: SNMP and APC rack power distribution units nick.rees
Next: Re: SNMP and APC rack power distribution units Robert Petkus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
