1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SNMP and APC rack power distribution units
To: [email protected]
Date: Thu, 24 Jun 2010 10:33:50 -0400
I've used smart PDUs from Servertech in the past ( http://www.servertech.com/products/smart-pdus/ ) and found them to be easy to use, versatile, and feature-rich.
For example, these units support input current monitoring and external temp & humidity probes configurable/accessible via SNMPv2, HTTP/S, and Telnet/SSH.  They are front-runners for use here.
As for devSNMP, I'll have to take a look at the releases posted by Nick.  The DESY download, while promising, needs work (scalability, v3 support, write).
Robert Petkus
Bldg. 902-B, 17 Cornell Avenue
National Synchrotron Light Source II
Brookhaven National Laboratory
Upton, New York 11973
Tel.       : +1 (631) 344 3258
Fax.      : +1 (631) 344 8085
-----Original Message-----
Sent: Thu 6/24/2010 9:06 AM
Subject: SNMP and APC rack power distribution units
We're thinking of using APC Ethernet-controllable rack power
distribution units.  One of the many ways you can talk to them is via
SNMP.
Has anyone used these or similar units?  And what is the status of EPICS
communicating via SNMP?
                                Sincerely,
                                        Elliott
 Those raised in a morally relative or neutral environment will hold
                    no truths to be self-evident.
Elliott Wolin
Staff Physicist, Jefferson Lab
12000 Jefferson Ave
Suite 8 MS 12A1
Newport News, VA 23606
757-269-7365
SNMP and APC rack power distribution units Elliott Wolin
Prev: Re: SNMP and APC rack power distribution units Matthieu Bec
Next: RE: Problems configuring 4 IK320 cards Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Pfeiffer Turbo Pump device driver Andrew C. Starritt
