I have the fink openmotif3
2.2.4-4 package installed on my OS X machine. Seems to work well with MEDM, EDM, StripTool and SDDSplot.
MEDM is an extension:
Unpack the config file tarball.
cd to the extensions directory created by unpacking the tarball. This directory will be referred to as the extensions <TOP> from now on
Edit the configure/RELEASE file top refer to where you have EPICS base installed.
Edit the configure/os/CONFIG_SITE.darwin-x86.darwin-x86 file and set up the correct references to your X11 and Motif packages.
cd to the <TOP> directory and run make
Now to download and build an extension -- medm in this case:
cd to the <TOP>/src directory and unpack the medm tarball
cd to the <TOP>/src/medm directory and run make
On Jun 21, 2010, at 6:06 PM, Andrew Wagner wrote:
Hey guys,
I'm new to EPICS and have compiled both EPICS base and Asyn successfully on my OS X 10.6.3 MacBook Pro. It seems that much of the driver support includes pre-made MEDM screens. Is there a good how-to manual for installing MEDM on OS X (or any os)? I've searched tech-talk and there definitely seem to be some pitfalls. For instance Motif 2.30 should be used instead of 2.32 to avoid some odd behavior. Thanks very much for the help.
Andrew Wagner
