1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MEDM installation instructions
To: Andrew Wagner <[email protected]>
Cc: [email protected]
Date: Tue, 22 Jun 2010 09:16:39 -0700
I have the fink openmotif3 2.2.4-4 package installed on my OS X machine.  Seems to work well with MEDM, EDM, StripTool and SDDSplot.
MEDM is an extension:
Download  the extensions configuration files from EPICS Extensions Config Files
Unpack the config file tarball.
cd to the extensions  directory created by unpacking the tarball.  This directory will be referred to as the extensions <TOP> from now on
Edit the configure/RELEASE file top refer to where you have EPICS base installed.
Edit the configure/os/CONFIG_SITE.darwin-x86.darwin-x86 file and set up the correct references to your X11 and Motif packages.
cd to the <TOP> directory and run make
Now to download and build an extension -- medm in this case:
Download the medm tarball:  MEDM 3.1.4
cd to the <TOP>/src directory and unpack the medm tarball
cd to the <TOP>/src/medm directory and run make
On Jun 21, 2010, at 6:06 PM, Andrew Wagner wrote:
Hey guys,
I'm new to EPICS and have compiled both EPICS base and Asyn successfully on my OS X 10.6.3 MacBook Pro. It seems that much of the driver support includes pre-made MEDM screens. Is there a good how-to manual for installing MEDM on OS X (or any os)? I've searched tech-talk and there definitely seem to be some pitfalls. For instance Motif 2.30 should be used instead of 2.32 to avoid some odd behavior. Thanks very much for the help.
Andrew Wagner
Eric Norum
[email protected]
Re: MEDM installation instructions Andrew Wagner
Prev: Re: Problems configuring 4 IK320 cards Ron Sluiter
Next: RE: Problems configuring 4 IK320 cards emma.shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MEDM installation instructions Andrew Wagner
Next: Re: MEDM installation instructions Andrew Wagner
