Andrew -
You didn't mention the model # of the scope ... it may already be
supported.
Rather than starting from scratch, I would suggest starting with
something close to what you want and modify it. Here is the link for
the Tek TDS3000 (and TDS5000 I believe) scope ...
http://www.aps.anl.gov/epics/modules/instrument/tds3000/index.html
You will also want to go through the tutorials for asyn ...
http://www.aps.anl.gov/epics/modules/soft/asyn/
You might not have to write any C/C++ code at all if you follow these
models ....
Ned
On Jun 21, 2010, at 3:41 AM, Andrew Wagner wrote:
Hey all,
I'm new to EPICS and was wondering if there was a very straight
forward, detailed tutorial for writing device support. Specifically,
I need to communicate with a Tektronix scope over Ethernet (the
scope has an IP address) and I would like to use my OS X laptop to
run the IOC. What libraries do I need to establish Ethernet
communication? Are they included in EPICS base? I didn't see
anything along those lines in the base-3-14-11/dev directory. I'm a
pretty experienced programer and run code on my laptop regularly. I
just don't have any experience with communication libraries in C/C+
+. Thanks very much for help.
Andrew Wagner
- Driver Support Tutorial Andrew Wagner
Re: Driver Support Tutorial Dirk Zimoch
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
