Hi Andrew,
Scopes with ethernet often use either the VXI11 protocol or a
telnet-like TCP connection. Both are supported by asynDriver.
http://www.aps.anl.gov/epics/modules/soft/asyn/
If the scope is programmed with plain text commands, you can use
StreamDevice on top of asynDriver.
http://epics.web.psi.ch/software/streamdevice/
No C-programming involved.
Best regards,
Dirk
Andrew Wagner wrote:
Hey all,
I'm new to EPICS and was wondering if there was a very straight forward, detailed tutorial for writing device support. Specifically, I need to communicate with a Tektronix scope over Ethernet (the scope has an IP address) and I would like to use my OS X laptop to run the IOC. What libraries do I need to establish Ethernet communication? Are they included in EPICS base? I didn't see anything along those lines in the base-3-14-11/dev directory. I'm a pretty experienced programer and run code on my laptop regularly. I just don't have any experience with communication libraries in C/C++. Thanks very much for help.
Andrew Wagner
- Driver Support Tutorial Andrew Wagner
Re: Driver Support Tutorial Ned Arnold
Re: Driver Support Tutorial Ralph Lange
<2010>
<2010>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
