1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MAXv vs XPS
To: Phillip Brown <[email protected]>
Cc: 郑丽芳 <[email protected]>, Scott Frederick <[email protected]>, Pro-Dex Beaverton Support Group <[email protected]>, Pro-Dex Customer Service <[email protected]>, 张招红 <[email protected]>, [email protected]
Date: Wed, 12 May 2010 05:29:50 -0500
Is this firmware upgrade considered to be a free warranty upgrade?
If not what is the cost for the firmware upgrade?
Marty Smith
Phillip Brown wrote:
> Hello Liu Ping,
> I can address the firmware upgrade of the old board that you have.  The controller with firmware version 1.31 must be returned to our facility to upgrade the firmware.  Our customer service department can provide an RMA number and the address to send the controller to ([email protected] or 1-800-707-8111).
> Best regards,
> Phil Brown
> Pro-Dex Oregon Micro Systems
> -----Original Message-----
> From: liuping [mailto:[email protected]]
> Sent: Tuesday, May 11, 2010 7:30 PM
> To: Phillip Brown; 'Ron Sluiter'; 'Mark Rivers'; Scott Frederick; [email protected]
> Cc: 张招红; 郑丽芳
> Hi All,
> ZHANG Zhaohong is my colleague. We want to resolve two problems.
> One is the reset problem of MAXv8000, the other is the problem of Autosave.
> In our experience, Autosave function can save the DVAL and DRBV fields. But
> after VME reboot or power up, only the value of DVAL is restored to motor
> recorder. In encoder close-loop control system, DRBV is not equal to DVAL
> normally. So in my opinion, the value of DRBV should be restored to motor
> recorder. Only DRBV indicates the current position of motor, because
> sometimes some defaults may cause the system crush and lets DRBV and DVAL
> have a large error. For example, let motor run a long distance, and suddenly
> the power is lost. I have not the ability of modifying the source codes of
> Autosave/Restore. So we hope EPICS experts give our some advises.
> About the D6 flash (watchdog reset problem), we have got the message as Mr.
> Ron Sluiter told me. Now according to Mr. Phillip Brown's answer, the MAXv
> board which has 1.33 or above firmware should resolve the issue. Fortunately
> there are more than ten boards from OMS in our hands, which were produced in
> this year(2010) and have the 1.33 firmware. In order to certify this, I use
> the command:
> dbior "drvMAXv"
> And get such message from IOC:
> Oms MAXv motor card #0 @ 0xF0F0F000, id: MAXv-8000 ver:1.33, s/n:000870,
> FPGA:B2:A6 BOOT:1.2 - Oregon Micro Systems value = 0 = 0x0
> Now what we can do is replace the old board (1.31 firmware) with new one (1.
> 33 firmware), wait and see.
> Welcome any suggestions.
> LIU Ping
> Beamline Control Group
> Shanghai Synchrotron Radiation Facility
> Shanghai Institute of Applied Physics
> Chinese Academy of Sciences
> Zhangheng Rd 239,Pudong Dist.,
> Shanghai 201204
> China
> Tel:+86-21-33933237
> : Phillip Brown [mailto:[email protected]]
> : 2010年5月11日 23:47
> : Ron Sluiter; Mark Rivers; Scott Frederick
> ; liuping
> : RE: MAXv vs XPS
> Hello All,
> Yes, the description is that the MAXv is in watchdog reset.  Ron is
> correct that the best thing is to send the controller back on RMA for
> analysis and firmware upgrade to version 1.33 or grater, which should
> resolve the issue.
> An RMA can be obtained by email ([email protected]) or phone
> (1-800-707-8111).
> Thanks,
> Phil
> From: Ron Sluiter [mailto:[email protected]]
> Sent: Tuesday, May 11, 2010 8:30 AM
> To: Mark Rivers; Scott Frederick; Phillip Brown
> Cc: ???; liuping
> Hello all,
> I have sent messages to both Zhang Zhaohong and
> Liu Ping (both from the Shanghai Institute of Applied Physics,
> but I don't know if these are the same or separate problem)
> that flashing LED's on the MAXv indicates the board
> may be experiencing the "reset problem" and that OMS has
> a firmware upgrade that they hope will address this.
> I suggested they RMA the MAXv board(s) back to OMS
> and request a firmware upgrade to version 1.33.
> There is a lot of communication going on here that
> might be resolved by a simple Return Materials
> Authorization (RMA).
> Ron
> Mark Rivers wrote:
>> I believe it is being done with a move command, not jog.
>> *From:* Scott Frederick [mailto:[email protected]]
>> *Sent:* Tuesday, May 11, 2010 10:00 AM
>> *To:* Mark Rivers
>> *Cc:* Phillip Brown; [email protected]
>> *Subject:* Re: MAXv vs XPS
>> Mark,
>> How is the Change on the fly performed through the MAXv? JG - Jog.
>> Scott
>> ----- Original Message -----
>> From: Mark Rivers <[email protected]>
>> To: Scott Frederick
>> Cc: Phillip Brown; Ron Sluiter <[email protected]>
>> Sent: Tue May 11 07:42:59 2010
>> Subject: RE: MAXv vs XPS
>> Hi Scott and Phil,
>> There is an EPICS user in China who is having a problem with a MAXv,
> and
>> I'm trying to help.  He says:
>> "When the user is doing the on-the-fly energy scanning(Bragg), the
>> corresponding MAXv crashes and has no any response to the input
> command.
>> The GREEN LED(D6) on the MAXv board flashes with GREEN LED(D4)
>> on.(Normally D6 is off and D4 is on)."
>> I looked in the MAXv manual and could not find a description of the
>> meaning of these LEDs.  Is this documented?
>> Thanks,
>> Mark
>> This e-mail and any attachment(s) are from Pro-Dex, Inc. and may
>> contain information that is confidential or privileged. If you are not
>> the intended recipient, do not read, copy or distribute the e-mail or
>> any attachments. Instead, please notify the sender at the phone number
>> indicated above and delete the e-mail and any attachments. Thank you.
> This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain
> information that is confidential or privileged. If you are not the intended
> recipient, do not read, copy or distribute the e-mail or any attachments.
> Instead, please notify the sender at the phone number indicated above and
> This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
RE: MAXv vs XPS Phillip Brown
Re: MAXv vs XPS liuping
Prev: Re: No monitor refresh Hinko Kocevar
Next: RE: No monitor refresh Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: MAXv vs XPS Phillip Brown
Next: RE: MAXv vs XPS Phillip Brown
