1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Problem Building SNC/SEQ Module
From: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
To: "'EPICS tech-talk'" <[email protected]>
Date: Thu, 29 Apr 2010 13:20:41 -0600
Hello,
I am trying to set up a new epics installation on a openSuse 11 system. I got epics base to compile fine. However, when I try to compile SNC/SEQ is get errors. I attached a log file, any help would be appreciated. Also, is there a standard convention for where to place modules in relation to base? Currently my directory structure looks like this:
/home/<user>/epics/
/home/<user>/epics/base
/home/<user>/epics/modules/sncseq
Not sure if this is correct (or if it matters). Thank you in advance.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
linux-wsk6:~/epics/modules/sncseq # make clean install
make -C ./configure clean
make[1]: Entering directory `/root/epics/modules/sncseq/configure'
rm -rf O.linux-x86 O.Common
make[1]: Leaving directory `/root/epics/modules/sncseq/configure'
make -C ./src clean
make[1]: Entering directory `/root/epics/modules/sncseq/src'
make -C ./pv clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/pv'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/pv'
make -C ./seq clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/seq'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/seq'
make -C ./dev clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/dev'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/dev'
make -C ./snc clean
make[2]: Entering directory `/root/epics/modules/sncseq/src/snc'
make[2]: Leaving directory `/root/epics/modules/sncseq/src/snc'
make[1]: Leaving directory `/root/epics/modules/sncseq/src'
make -C ./test clean
make[1]: Entering directory `/root/epics/modules/sncseq/test'
make -C ./simple clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/simple'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/simple'
make -C ./validate clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/validate'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/validate'
make -C ./demo clean
make[2]: Entering directory `/root/epics/modules/sncseq/test/demo'
make[2]: Leaving directory `/root/epics/modules/sncseq/test/demo'
make[1]: Leaving directory `/root/epics/modules/sncseq/test'
make -C ./configure install
perl /root/epics/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
`/root/epics/modules/sncseq/configure/O.linux-x86'
perl /root/epics/base/bin/linux-x86/convertRelease.pl checkRelease
make -C ./src install
make -C ./pv install
perl /root/epics/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/root/epics/modules/sncseq/src/pv/O.linux-x86'
Installing generic include file ../../../include/pv.h
mkdir ../../../include
Installing generic include file ../../../include/pvAlarm.h
Installing generic include file ../../../include/pvCa.h
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500          -DPVCA  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I.
-I.. -I../../../include/os/Linux -I../../../include
-I/root/epics/base/include/os/Linux -I/root/epics/base/include
../pvNew.cc
../pv.cc
../pvCa.cc
/usr/bin/ar -rc   libpv.a        pvNew.o pv.o pvCa.o
/usr/bin/ranlib libpv.a
/usr/bin/g++ -o libpv.so -shared -fPIC -Wl,-hlibpv.so
-L/root/epics/base/lib/linux-x86 -Wl,-rpath,/root/epics/base/lib/linux-x86
    -m32               pvNew.o pv.o pvCa.o    -lca -lCom   -lpthread
-lreadline -lncurses -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libpv.so
mkdir ../../../lib
mkdir ../../../lib/linux-x86
Installing library ../../../lib/linux-x86/libpv.a
/usr/bin/ranlib ../../../lib/linux-x86/libpv.a
make[3]: Leaving directory `/root/epics/modules/sncseq/src/pv/O.linux-x86'
make -C ./seq install
mkdir O.Common
`/root/epics/modules/sncseq/src/seq/O.linux-x86'
Installing generic include file ../../../include/seqCom.h
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
../seq_main.c
../seq_task.c
../seq_task.c: In function ?sequencer?:
../seq_task.c:122: warning: call to function ?ss_entry? without a real prototype
../seq_task.c:81: note: ?ss_entry? was declared here
../seq_ca.c
../seq_if.c
../seq_mac.c
../seq_prog.c
../seq_qry.c
rm -f seqVersion.c
perl ../seqVersion.pl 2.0.12 > seqVersion.c
seqVersion.c
../seqCommands.c
/usr/bin/ar -rc   libseq.a         seq_main.o seq_task.o seq_ca.o seq_if.o
seq_mac.o seq_prog.o seq_qry.o seqVersion.o seqCommands.o
/usr/bin/ranlib libseq.a
/usr/bin/g++ -o libseq.so -shared -fPIC -Wl,-hlibseq.so
-L/root/epics/modules/sncseq/lib/linux-x86 -L/root/epics/base/lib/linux-x86
-Wl,-rpath,/root/epics/modules/sncseq/lib/linux-x86
-Wl,-rpath,/root/epics/base/lib/linux-x86       -m32
seq_main.o seq_task.o seq_ca.o seq_if.o seq_mac.o seq_prog.o seq_qry.o
seqVersion.o seqCommands.o   -lpv -lCom   -lpthread   -lreadline -lncurses
-lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libseq.so
Installing library ../../../lib/linux-x86/libseq.a
/usr/bin/ranlib ../../../lib/linux-x86/libseq.a
make -C ./dev install
mkdir O.Common
`/root/epics/modules/sncseq/src/dev/O.linux-x86'
Installing dbd file ../../../dbd/devSequencer.dbd
mkdir ../../../dbd
-D_REENTRANT   -O3   -Wall     -I../../seq  -m32     -g -fPIC -I.
-I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include
../devSequencer.c
../devSequencer.c: In function ?seqShowScanPvtInit?:
../devSequencer.c:191: warning: comparison between pointer and integer
../devSequencer.c:198: warning: comparison between pointer and integer
../devSequencer.c:199: warning: assignment makes integer from pointer
without a cast
/usr/bin/ar -rc   libseqDev.a         devSequencer.o
/usr/bin/ranlib libseqDev.a
/usr/bin/g++ -o libseqDev.so -shared -fPIC -Wl,-hlibseqDev.so
devSequencer.o   -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc
-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
-lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libseqDev.so
Installing library ../../../lib/linux-x86/libseqDev.a
/usr/bin/ranlib ../../../lib/linux-x86/libseqDev.a
make -C ./snc install
mkdir O.Common
`/root/epics/modules/sncseq/src/snc/O.linux-x86'
-D_REENTRANT   -O3   -Wall      -m32     -g  -I. -I../O.Common -I. -I..
../snc_main.c
../snc_main.c: In function ?main?:
../snc_main.c:90: warning: call to function ?get_args? without a real prototype
../snc_main.c:58: note: ?get_args? was declared here
../snc_main.c: In function ?get_args?:
../snc_main.c:158: warning: call to function ?get_in_file? without a real
prototype
../snc_main.c:60: note: ?get_in_file? was declared here
../snc_main.c:163: warning: call to function ?get_out_file? without a real
prototype
../snc_main.c:61: note: ?get_out_file? was declared here
../snc_main.c:167: warning: call to function ?get_options? without a real
prototype
../snc_main.c:59: note: ?get_options? was declared here
../parse.c
../parse.c: In function ?decl_stmt?:
../parse.c:135: warning: call to function ?findVar? without a real
prototype
../parse.h:87: note: ?findVar? was declared here
../parse.c: In function ?assign_single?:
../parse.c:212: warning: call to function ?findVar? without a real
prototype
../parse.c:229: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:69: note: ?build_db_struct? was declared here
../parse.c: In function ?assign_subscr?:
../parse.c:255: warning: call to function ?findVar? without a real
prototype
../parse.c:274: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:293: warning: call to function ?alloc_db_lists? without a real
prototype
../parse.c:70: note: ?alloc_db_lists? was declared here
../parse.c: In function ?assign_list?:
../parse.c:328: warning: call to function ?findVar? without a real
prototype
../parse.c:352: warning: call to function ?build_db_struct? without a real
prototype
../parse.c:355: warning: call to function ?alloc_db_lists? without a real
prototype
../parse.c: In function ?build_db_struct?:
../parse.c:385: warning: call to function ?addChan? without a real
prototype
../parse.c:72: note: ?addChan? was declared here
../parse.c: In function ?monitor_stmt?:
../parse.c:446: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?sync_stmt?:
../parse.c:515: warning: call to function ?findVar? without a real
prototype
../parse.c:532: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?syncq_stmt?:
../parse.c:589: warning: call to function ?findVar? without a real
prototype
../parse.c:614: warning: call to function ?findVar? without a real
prototype
../parse.c: In function ?defn_c_stmt?:
../parse.c:676: warning: call to function ?link_expr? without a real prototype
../parse.h:86: note: ?link_expr? was declared here
../phase2.c
../phase2.c: In function ?gen_preamble?:
../phase2.c:155: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:56: note: ?gen_opt_defn? was declared here
../phase2.c:156: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:157: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:158: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:159: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c:160: warning: call to function ?gen_opt_defn? without a real
prototype
../phase2.c: In function ?connect_variable?:
../phase2.c:250: warning: call to function ?findVar? without a real
prototype
../phase2.c: In function ?gen_defn_c_code?:
../phase2.c:432: warning: format ?%s? expects type ?char *?, but argument
2 has type ?struct expression *?
../phase2.c: In function ?gen_global_c_code?:
../phase2.c:450: warning: format ?%s? expects type ?char *?, but argument
../gen_ss_code.c
../gen_ss_code.c: In function ?gen_action_func?:
../gen_ss_code.c:302: warning: format ?%s? expects type ?char *?, but
argument 2 has type ?struct expression *?
../gen_ss_code.c: In function ?eval_expr?:
../gen_ss_code.c:569: warning: format ?%s? expects type ?char *?, but
../gen_ss_code.c: In function ?gen_ef_func?:
../gen_ss_code.c:728: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c: In function ?gen_pv_func?:
../gen_ss_code.c:792: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c:800: warning: call to function ?findVar? without a real
prototype
../gen_ss_code.c:769: warning: ?ep3? may be used uninitialized in this function /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
../gen_tables.c
../gen_tables.c: In function ?gen_db_blocks?:
../gen_tables.c:112: warning: call to function ?fill_db_block? without a
real prototype
../gen_tables.c:42: note: ?fill_db_block? was declared here
../gen_tables.c:119: warning: call to function ?fill_db_block? without a
real prototype
../gen_tables.c: In function ?fill_db_block?:
../gen_tables.c:194: warning: call to function ?db_type_str? without a
real prototype
../gen_tables.c:144: note: ?db_type_str? was declared here
../gen_tables.c: In function ?gen_state_blocks?:
../gen_tables.c:263: warning: call to function ?eval_state_event_mask?
../gen_tables.c:49: note: ?eval_state_event_mask? was declared here
../gen_tables.c:278: warning: call to function ?fill_state_block? without
a real prototype
../gen_tables.c:44: note: ?fill_state_block? was declared here
../gen_tables.c: In function ?gen_ss_array?:
../gen_tables.c:540: warning: call to function ?find_error_state? without
a real prototype
../gen_tables.c:53: note: ?find_error_state? was declared here
/root/epics/base/bin/linux-x86/e_flex
-S/root/epics/base/include/flex.skel.static -8 -I ../snc_lex.l
mv lex.yy.c snc_lex.c
rm -f snc.c y.tab.c
rm -f snc.h y.tab.h
/root/epics/base/bin/linux-x86/antelope -d -v ../snc.y
/root/epics/base/bin/linux-x86/antelope: 474 shift/reduce conflicts, 270
reduce/reduce conflicts.
mv y.tab.c snc.c
mv y.tab.h snc.h
-I/root/epics/base/include/os/Linux -I/root/epics/base/include        snc.c
In file included from ../snc.y:476:
../snc_lex.l: In function ?yy_get_next_buffer?:
../snc_lex.l:446: warning: implicit declaration of function ?read?
y.tab.c: In function ?yyparse?:
y.tab.c:1100: warning: implicit declaration of function ?yyerror?
../snc.y:113: warning: implicit declaration of function ?program?
../snc.y:117: warning: implicit declaration of function ?snc_err?
../snc.y:121: warning: implicit declaration of function ?program_name?
../snc.y:144: warning: implicit declaration of function ?assign_single?
../snc.y:146: warning: implicit declaration of function ?assign_subscr?
../snc.y:149: warning: implicit declaration of function ?assign_list?
../snc.y:153: warning: call to function ?expression? without a real
prototype
../parse.h:86: note: ?expression? was declared here
../snc.y:155: warning: call to function ?expression? without a real
prototype
../snc.y:155: warning: call to function ?link_expr? without a real
prototype
../snc.y:164: warning: implicit declaration of function ?monitor_stmt?
../snc.y:173: warning: implicit declaration of function ?set_debug_print?
../snc.y:179: warning: implicit declaration of function ?decl_stmt?
../snc.y:202: warning: call to function ?expression? without a real
prototype
../snc.y:204: warning: call to function ?expression? without a real
prototype
../snc.y:224: warning: implicit declaration of function ?sync_stmt?
../snc.y:229: warning: implicit declaration of function ?syncq_stmt?
../snc.y:239: warning: implicit declaration of function ?defn_c_stmt?
../snc.y:243: warning: implicit declaration of function ?option_stmt?
../snc.y:249: warning: call to function ?link_expr? without a real
prototype
../snc.y:254: warning: call to function ?expression? without a real
prototype
../snc.y:256: warning: implicit declaration of function ?entry_code?
../snc.y:258: warning: implicit declaration of function ?exit_code?
../snc.y:265: warning: call to function ?link_expr? without a real
prototype
../snc.y:271: warning: call to function ?expression? without a real
prototype
../snc.y:279: warning: call to function ?link_expr? without a real
prototype
../snc.y:285: warning: call to function ?expression? without a real
prototype
../snc.y:287: warning: call to function ?expression? without a real
prototype
../snc.y:293: warning: call to function ?link_expr? without a real
prototype
prototype
../snc.y:300: warning: call to function ?link_expr? without a real
prototype
../snc.y:306: warning: call to function ?link_expr? without a real
prototype
../snc.y:311: warning: call to function ?expression? without a real
prototype
../snc.y:317: warning: call to function ?expression? without a real
prototype
../snc.y:323: warning: call to function ?link_expr? without a real
prototype
../snc.y:329: warning: call to function ?expression? without a real
prototype
../snc.y:337: warning: call to function ?expression? without a real
prototype
../snc.y:338: warning: call to function ?expression? without a real
prototype
../snc.y:339: warning: call to function ?expression? without a real
prototype
../snc.y:340: warning: call to function ?expression? without a real
prototype
../snc.y:341: warning: call to function ?expression? without a real
prototype
../snc.y:342: warning: call to function ?expression? without a real
prototype
../snc.y:343: warning: call to function ?expression? without a real
prototype
../snc.y:344: warning: call to function ?expression? without a real
prototype
../snc.y:345: warning: call to function ?expression? without a real
prototype
../snc.y:346: warning: call to function ?expression? without a real
prototype
../snc.y:347: warning: call to function ?expression? without a real
prototype
../snc.y:348: warning: call to function ?expression? without a real
prototype
../snc.y:349: warning: call to function ?expression? without a real
prototype
../snc.y:350: warning: call to function ?expression? without a real
prototype
../snc.y:351: warning: call to function ?expression? without a real
prototype
../snc.y:352: warning: call to function ?expression? without a real
prototype
../snc.y:357: warning: call to function ?link_expr? without a real
prototype
../snc.y:358: warning: call to function ?link_expr? without a real
prototype
../snc.y:414: warning: call to function ?expression? without a real
prototype
../snc.y:420: warning: call to function ?link_expr? without a real
prototype
../snc.y:426: warning: call to function ?expression? without a real
prototype
../snc.y:427: warning: call to function ?expression? without a real
prototype
../snc.y:432: warning: call to function ?expression? without a real
prototype
../snc.y:438: warning: call to function ?expression? without a real
prototype
../snc.y:442: warning: call to function ?expression? without a real
prototype
../snc.y:446: warning: call to function ?expression? without a real
prototype
../snc.y:451: warning: call to function ?expression? without a real
prototype
../snc.y:452: warning: call to function ?expression? without a real
prototype
prototype
../snc.y:456: warning: implicit declaration of function ?pp_code?
../snc.y:468: warning: implicit declaration of function ?global_c_stmt?
../snc.y:472: warning: call to function ?expression? without a real prototype
../snc.y:473: warning: call to function ?expression? without a real prototype
../snc.y:473: warning: call to function ?link_expr? without a real prototype
y.tab.c: At top level:
../snc_lex.l:554: warning: ?yyunput? defined but not used
../snc_lex.l:661: warning: ?yyrestart? defined but not used
../snc_lex.l:673: warning: ?yy_switch_to_buffer? defined but not used
../snc_lex.l:597: warning: ?input? defined but not used rm -f sncVersion.c perl ../sncVersion.pl 2.0.12 > sncVersion.c /usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
sncVersion.c
/usr/bin/g++ -o snc  -L/root/epics/base/lib/linux-x86
snc_main.o parse.o phase2.o gen_ss_code.o gen_tables.o snc.o sncVersion.o -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lfl
/usr/lib/gcc/i586-suse-linux/4.3/../../../../i586-suse-linux/bin/ld:
cannot find -lfl
collect2: ld returned 1 exit status
make[3]: *** [snc] Error 1
make[2]: *** [install.linux-x86] Error 2
make[1]: *** [snc.install] Error 2
make: *** [src.install] Error 2
RE: Problem Building SNC/SEQ Module Mark Rivers
Prev: LabVIEW Native Channel Access for EPICS Alan Greer
Next: RE: Problem Building SNC/SEQ Module Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
