A little more investigation shows that in snc/Makefile there is the following:
# Lex library
SYS_PROD_LIBS_WIN32 += -nil-
SYS_PROD_LIBS_cygwin32 += -nil-
SYS_PROD_LIBS_Linux += fl
SYS_PROD_LIBS_DEFAULT += l
So Linux does require the Lex library. On Fedora you could install this with "yum install flex".
To answer your question about the location of modules relative to base I think many sites keep these completely separate. EPICS_BASE in configure/RELEASE just points to where you keep base.
From: [email protected] on behalf of Pawel Kowalski - BiRa Systems Inc.
Sent: Thu 4/29/2010 2:20 PM
To: 'EPICS tech-talk'
Subject: Problem Building SNC/SEQ Module
Hello,
I am trying to set up a new epics installation on a openSuse 11 system. I got epics base to compile fine. However, when I try to compile SNC/SEQ is get errors. I attached a log file, any help would be appreciated. Also, is there a standard convention for where to place modules in relation to base? Currently my directory structure looks like this:
/home/<user>/epics/
/home/<user>/epics/base
/home/<user>/epics/modules/sncseq
Not sure if this is correct (or if it matters). Thank you in advance.
Pawel Kowalski
BiRa Systems Inc.
www.bira.com <http://www.bira.com/>
Phone: 505-881-8887
Fax: 505-888-0651
Address: 2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
- Re: Problem Building SNC/SEQ Module Andrew Johnson
- Problem Building SNC/SEQ Module Pawel Kowalski - BiRa Systems Inc.
RE: Problem Building SNC/SEQ Module Mark Rivers
<2010>
<2010>
