Subject: |
RE: Building StreamDevice 2-4 / SynApps / Win32 |
John Dobbins <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Fri, 12 Mar 2010 14:53:32 -0500 |
I have found that the Makefile in the StreamDevice directory srcSynApps has a similar behavior. So I'll apply the same change.
John
From: [email protected] [[email protected]] On Behalf Of John Dobbins [[email protected]]
Sent: Friday, March 12, 2010 2:47 PM
To: EPICS Tech-Talk
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
First, thanks to everyone for the help with understanding what the problem was in the first place, i.e. that one of the StreamDevice Makefiles depends on certain shell capabilities.
I like the fact that I have been able to build EPICS on Windows with the only the dependencies being GnuMake and Perl. So what I have done is to change the StreamDevice Makefile to call two new Perl scripts. My Makefile for the StreamDevice src directory now looks like:
MAKE_STREAM_DBD_CMD = "../makeStreamDbd.pl"
MAKE_STREAM_REFERENCES_CMD = "../makeStreamReferences.pl"
streamReferences: ../CONFIG_STREAM
@$(MAKE_STREAM_REFERENCES_CMD) $(BUSSES) : $(FORMATS)
# create stream.dbd from all RECORDS
$(COMMON_DIR)/$(LIBRARY_DEFAULT).dbd: ../CONFIG_STREAM
@$(MAKE_STREAM_DBD_CMD) $(COMMON_DIR) $(LIBRARY_DEFAULT) $(RECORDS)
I have attached the the Perl scripts I created.
Feel free to suggest improvements that would make this better conform to the standards of the EPICS build system.
John Dobbins
John Dobbins wrote:
> Dear All,
> I am trying to build StreamDevice 2-4 on win32-x86
> I happen to be using the synApps source and the Makefile is show below
> The directories structure is:
> support/
> asyn
> std
> stream
> Everything works fine until I get to stream at which point I get the cryptic error "r was unexpected at this time."
> details:
> make[4]: Entering directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
> make[4]: *** [../O.Common/stream.dbd] Error 255
> make[4]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
> make[3]: *** [install.win32-x86] Error 2
> make[3]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src'
> make[2]: *** [src.install] Error 2
> make[2]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4'
> make[1]: *** [StreamDevice-2-4.install] Error 2
> make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4'
> make: *** [W:/winDev/epics/R3.14.10/support/stream/2-4.install] Error 2
> W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86' looks like
> #This Makefile created by makeMakefile.pl
> all :
> $(MAKE) -f ../Makefile TOP=../../.. T_A=win32-x86 $@
> .DEFAULT: force
> force: ;
> Advice anyone?
> Thanks,
> John Dobbins
> Lab for Elementary Particle Physics
> Cornell University
> #FILENAME: Makefile
> #USAGE: Top Makefile
> #Version: 1.5
> #Modified By: mooney
> #Last Modified: 2009/03/06 21:31:25
> #NOTES- The "SUPPORT_DIRS" order is based on compile time dependencies.
> # - The user must modify SUPPORT and EPICS_BASE in the
> # <synApps>/support/configure directory for the local configuration.
> # - To support multiple configurations, use multiple configure* directories
> # - Support modules can be shared between configurations only if
> # dependencies are not violated. Only the "DIRS" are the target of
> # gnumake. If this configuration is using a support module built by
> # another configuration, then the SUPPORT_DIRS line for that support
> # module must be commented out (i.e, must begin with a '#').
> # Note the only dependencies that matter in $(<module>)_DEPEND_DIRS are
> # compile-time dependencies.
> TOP = .
> MASTER_FILE = $(TOP)/configure/RELEASE.win32-x86
> include $(TOP)/configure/CONFIG
> ###### 1st Tier Support Modules - Only Depend on EPICS BASE ######
> SUPPORT_DIRS += $(SNCSEQ)
> RELEASE_FILES += $(SNCSEQ)/configure/RELEASE.win32-x86
> SUPPORT_DIRS += $(SSCAN)
> RELEASE_FILES += $(SSCAN)/configure/RELEASE.win32-x86
> SUPPORT_DIRS += $(AUTOSAVE)
> RELEASE_FILES += $(AUTOSAVE)/configure/RELEASE.win32-x86
> ###### 2nd Tier Support Modules - Only Depend on 1st Tier ########
> SUPPORT_DIRS += $(ASYN)
> RELEASE_FILES += $(ASYN)/configure/RELEASE.win32-x86
> $(ASYN)_DEPEND_DIRS = $(SNCSEQ)
> SUPPORT_DIRS += $(CALC)
> RELEASE_FILES += $(CALC)/configure/RELEASE.win32-x86
> $(CALC)_DEPEND_DIRS = $(SSCAN)
> ################### 3rd Tier Support Modules #####################
> SUPPORT_DIRS += $(BUSY)
> RELEASE_FILES += $(BUSY)/configure/RELEASE.win32-x86
> $(BUSY)_DEPEND_DIRS = $(ASYN)
> SUPPORT_DIRS += $(STD)
> RELEASE_FILES += $(STD)/configure/RELEASE.win32-x86
> $(STD)_DEPEND_DIRS = $(ASYN)
> SUPPORT_DIRS += $(STREAM)
> RELEASE_FILES += $(STREAM)/configure/RELEASE.win32-x86
> $(STREAM)_DEPEND_DIRS = $(ASYN) $(CALC) $(SSCAN)
> ################### 4th Tier Support Modules #####################
> #SUPPORT_DIRS += $(MCA)
> #RELEASE_FILES += $(MCA)/configure/RELEASE.win32-x86
> #$(MCA)_DEPEND_DIRS = $(ASYN) $(STD)
> ################### 5th Tier Support Modules #####################
> #SUPPORT_DIRS += $(AREA_DETECTOR)
> #RELEASE_FILES += $(AREA_DETECTOR)/configure/RELEASE.win32-x86
> #$(AREA_DETECTOR)_DEPEND_DIRS = $(ASYN) $(SSCAN) $(MCA)
> ################### End of Support-Modules #####################
> DIRS = $(SUPPORT_DIRS)
> ################### User Modules #####################
> ACTIONS += uninstall realuninstall distclean cvsclean
> include $(EPICS_BASE)/configure/RULES_TOP
> release:
> echo SUPPORT=$(SUPPORT)
> echo ' '
> echo EPICS_BASE=$(EPICS_BASE)
> echo ' '
> echo MASTER_FILE=$(MASTER_FILE)
> echo ' '
> echo DIRS=$(DIRS)
> echo ' '
> echo RELEASE_FILES=$(RELEASE_FILES)
> echo ' '
> $(PERL) $(TOP)/configure/makeReleaseConsistent.pl $(SUPPORT) $(EPICS_BASE) $(MASTER_FILE) $(RELEASE_FILES)
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
INP field length Steve Kinder
<2010>
IS SDDS not avaible? 汪启胜
<2010>
