1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Building StreamDevice 2-4 / SynApps / Win32
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 11 Mar 2010 12:09:24 -0500
Dear All,
I am trying to build StreamDevice 2-4 on win32-x86
I happen to be using the synApps source and the Makefile is show below
The directories structure is:
support/
   asyn
   std
   stream
Everything works fine until I get to stream at which point I get the cryptic error "r was unexpected at this time."
details:
make[4]: Entering directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
make[4]: *** [../O.Common/stream.dbd] Error 255
make[4]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src'
make[2]: *** [src.install] Error 2
make[2]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4'
make[1]: *** [StreamDevice-2-4.install] Error 2
make[1]: Leaving directory `W:/winDev/epics/R3.14.10/support/stream/2-4'
make: *** [W:/winDev/epics/R3.14.10/support/stream/2-4.install] Error 2
W:/winDev/epics/R3.14.10/support/stream/2-4/StreamDevice-2-4/src/O.win32-x86' looks like
  #This Makefile created by makeMakefile.pl
  all :
	  $(MAKE) -f ../Makefile TOP=../../.. T_A=win32-x86  $@
  .DEFAULT: force
  force:  ;
Advice anyone?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
#FILENAME:	Makefile
#USAGE:		Top Makefile
#Version:	1.5
#Modified By:	mooney
#Last Modified:	2009/03/06 21:31:25
#NOTES- The "SUPPORT_DIRS" order is based on compile time dependencies.
#     - The user must modify SUPPORT and EPICS_BASE in the
#       <synApps>/support/configure directory for the local configuration.
#     - To support multiple configurations, use multiple configure* directories
#     - Support modules can be shared between configurations only if
#	dependencies are not violated.  Only the "DIRS" are the target of
#	gnumake.  If this configuration is using a support module built by
#	another configuration, then the	SUPPORT_DIRS line for that support
#	module must be commented out (i.e, must begin with a '#').
# Note the only dependencies that matter in $(<module>)_DEPEND_DIRS are
# compile-time dependencies.
TOP = .
MASTER_FILE = $(TOP)/configure/RELEASE.win32-x86
include $(TOP)/configure/CONFIG
###### 1st Tier Support Modules - Only Depend on EPICS BASE ######
SUPPORT_DIRS += $(SNCSEQ)
RELEASE_FILES += $(SNCSEQ)/configure/RELEASE.win32-x86
SUPPORT_DIRS += $(SSCAN)
RELEASE_FILES += $(SSCAN)/configure/RELEASE.win32-x86
SUPPORT_DIRS += $(AUTOSAVE)
RELEASE_FILES += $(AUTOSAVE)/configure/RELEASE.win32-x86
###### 2nd Tier Support Modules - Only Depend on 1st Tier ########
SUPPORT_DIRS += $(ASYN)
RELEASE_FILES += $(ASYN)/configure/RELEASE.win32-x86
$(ASYN)_DEPEND_DIRS = $(SNCSEQ)
SUPPORT_DIRS += $(CALC)
RELEASE_FILES += $(CALC)/configure/RELEASE.win32-x86
$(CALC)_DEPEND_DIRS = $(SSCAN)
################### 3rd Tier Support Modules #####################
SUPPORT_DIRS += $(BUSY)
RELEASE_FILES += $(BUSY)/configure/RELEASE.win32-x86
$(BUSY)_DEPEND_DIRS = $(ASYN)
SUPPORT_DIRS += $(STD)
RELEASE_FILES += $(STD)/configure/RELEASE.win32-x86
$(STD)_DEPEND_DIRS = $(ASYN)
SUPPORT_DIRS += $(STREAM)
RELEASE_FILES += $(STREAM)/configure/RELEASE.win32-x86
$(STREAM)_DEPEND_DIRS = $(ASYN) $(CALC) $(SSCAN)
################### 4th Tier Support Modules #####################
#SUPPORT_DIRS += $(MCA)
#RELEASE_FILES += $(MCA)/configure/RELEASE.win32-x86
#$(MCA)_DEPEND_DIRS = $(ASYN) $(STD)
################### 5th Tier Support Modules #####################
#SUPPORT_DIRS += $(AREA_DETECTOR)
#RELEASE_FILES += $(AREA_DETECTOR)/configure/RELEASE.win32-x86
#$(AREA_DETECTOR)_DEPEND_DIRS = $(ASYN) $(SSCAN) $(MCA)
################### End of Support-Modules #####################
DIRS = $(SUPPORT_DIRS)
################### User Modules #####################
ACTIONS += uninstall realuninstall distclean cvsclean
include $(EPICS_BASE)/configure/RULES_TOP
release:
	echo SUPPORT=$(SUPPORT)
	echo ' '
	echo EPICS_BASE=$(EPICS_BASE)
	echo ' '
	echo MASTER_FILE=$(MASTER_FILE)
	echo ' '
	echo DIRS=$(DIRS)
	echo ' '
	echo RELEASE_FILES=$(RELEASE_FILES)
	echo ' '
	$(PERL) $(TOP)/configure/makeReleaseConsistent.pl $(SUPPORT) $(EPICS_BASE) $(MASTER_FILE) $(RELEASE_FILES)
RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Prev: Re: 2 MAXv problems Dirk Zimoch
Next: RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: IP asyn timeout connection Dominique Touchard
