On 3/12/10 4:04 AM, Dirk Zimoch wrote:
> John,
> I have verified that "r was unexpected at this time" is an error message
> from the windows command interpreter. I put this (bash) code into a
> *.bat file:
> for r in a b c; do echo $r; done
> and executed the bat file and got the same error message.
> I have no idea how the windows shell works. Better use bash from cygwin.
Hi, Dirk.
But what do you mean by "Better use bash from cygwin?" Are you
suggesting that John should run "make" from a bash shell from Cygwin?
That's what I'm saying is not what I would expect to make a difference.
What's important is what shell make is using to execute the commands
for each target. This is why I suggested checking what the default
shell is for the make included with GnuWin32 and checking if the SHELL
make variable had been set and, if so, to what?
>From what you've said above, it looks like perhaps make is using the
Windows command interpreter as the shell rather than a Bourne shell. So
if John were to set the make SHELL variable to /bin/sh (or wherever it
is for GnuWin32) then perhaps his problem would be solved.
Lewis
- Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
- RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
- Re: Building StreamDevice 2-4 / SynApps / Win32 Dirk Zimoch
Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
<2010>
<2010>
