1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system.
To: [email protected]
Date: Tue, 02 Mar 2010 09:32:39 -0600
On 3/1/10 5:29 PM, Ramu Denduluri wrote:
> Hi All,
>      While installing the medm 3.1.3 on 64 bit Fedora 11 operation
> system, I got following compilation error.
> gcc -ansi -pedantic    -D_POSIX_C_SOURCE=199506L   -O3  -Wall
> -DEDITRES -D_X86_64_ -Dlinux -fPIC -D_REENTRANT  -DUNIX -D_BSD_SOURCE
> -I. -I.. -I../../printUtils -I../../xc -I -I
> -I../../../../include/os/Linux -I../../../../include
> -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include/os/Linux
> -I/home/clsfs/epics/prod/cr1dev3/epics-base-3.14.11/include   -c
> ../utils.c
> ../utils.c: In function 'doRubberbanding':
> ../utils.c:965: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doDragging':
> ../utils.c:1160: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doPasting':
> ../utils.c:1400: warning: cast from pointer to integer of different size
> ../utils.c: In function 'doResizing':
> ../utils.c:1658: warning: cast from pointer to integer of different size
> ../utils.c: In function 'parseAndExecCommand':
> ../utils.c:4268: warning: the address of 'command' will always evaluate
> as 'true'
> ../utils.c:4743:2: error: #error getEventType only works for
> LASTEvent=35 (See X.h)
> make[2]: *** [utils.o] Error 1
> make[2]: Leaving directory
> `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm/O.linux-x86_64'
> make[1]: *** [buildInstall.linux-x86_64] Error 2
> make[1]: Leaving directory
> `/usr/local/src/epics-extensions-3.14.11-20100224_114640/src/medm-3.1.1/medm'
> make: *** [medm.buildInstall] Error 2
> I am using epics-base 3.14.11 and could you please help me in fixing
> this issue.
Hi, Ramu.
I think upgrading to MEDM 3.1.4 will fix this.  See this Tech-Talk thread:
  http://www.aps.anl.gov/epics/tech-talk/2009/msg00268.php
Lewis
Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. Ramu Denduluri
Prev: edm table collapsing Pierrick Hanlet
Next: compile error with medm 3.1.3 on fedora 10 Hitesh
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. Ramu Denduluri
Next: edm table collapsing Pierrick Hanlet
