1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: edm table collapsing
Date: Mon, 01 Mar 2010 23:10:10 -0600
I'm using 3.14.11 on a linux system with a soft ioc.  I am using edm table.  Until recently, the table
worked as advertised, but upon changing the size of the display and then the size of the table, I
find that the table will print successfully once, then when updating after a scan will collapse to a
box 2mm X 2mm.  Has anyone ever seen this before?  More importantly, how do I fix it?
Resizing doesn't help.
Thank you,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Prev: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. Ramu Denduluri
Next: Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Compilation errors associated to medm 3.1.3 on 64 bit Fedora 11 operating system. J. Lewis Muir
Next: compile error with medm 3.1.3 on fedora 10 Hitesh
