1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: dbLoadTemplate issue in 3.14.9-11
To: "[email protected]" <[email protected]>, [email protected]
Date: Wed, 27 Jan 2010 12:05:47 -0800
msi is compiled and working for all of my epics base versions.
But dbLoadTemplate directive doesn't work.
Do I need to change my CONFIG directory for msi?
I remember doing this in the past...
The error I get is :
dbLoadTemplate("my.substitution")
Error: syntax error
Parsing 'dbl'
  in path "." file my.substitution line 1
dbl is on the first line of my sub file.
I get one error for each of my instance of the template file.
Note that if my sub file is empty I still get the same error (or almost, without the dbl).
So the files are found, but the parsing is not working correctly.
What am I doing wrong?
Emmanuel
Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
Re: dbLoadTemplate issue in 3.14.9-11 Andrew Johnson
Prev: RE: compact PCI versus VME Jeff Hill
Next: Re: dbLoadTemplate issue in 3.14.9-11 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: compact PCI versus VME Dalesio, Leo
