Hi all,
I have a quite nasty problem with the mbboDirect record.
When I write a bit pattern directly into the VAL field instead of B0...BF, and
the record has UDF=1, the record writes out the old value instead of the new
one. According to the record reference manual, this is not an illegal operation.
Normally it works. Even if the UDF becomes true during run-time, the worst thing
that happens is that the new value is ignored (which is already bad enough). But
after a reboot the record writes out 0 (and thus switches off all connected
hardware).
The problem is here:
static long process(mbboDirectRecord *prec)
if (!prec->pact) {
if(prec->udf) {
recGblSetSevr(prec,UDF_ALARM,INVALID_ALARM);
goto CONTINUE;
/* convert val to rval */
convert(prec);
CONTINUE:
I am not sure what the purpose of this code is. The record never sets udf true.
Thus only the device support can do so. Thus it cannot make sense the test udf
BEFORE the device support is called.
Best regards,
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: mbboDirect problem Andrew Johnson
Re: Remote I/O John William Sinclair
Re: Remote I/O & RT linux David Dudley
<2009>
labCa 3.1 for Windows John Dobbins
<2009>
