1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Remote I/O
To: David Dudley <[email protected]>
Date: Fri, 18 Dec 2009 01:05:47 -0500
Note that ControlLogix communications (multicast with tcp messaging) includes a fairly severe penalty for using the tag names. There are a limited number of cip resources (255 is common). Each module consumes several and each IOC access by tag name consumes one. As a result, we always use arrays and end up in the same old boat of having to do lots of name mapping to array position. In principle the tag names are very nice; in practice they are not too useful.
John Sinclair
David Dudley wrote:
For NSLS-2, all configuration and logic is planned to be incorporated into the IRMIS system, as a single database layout.
In addition, I should have initially mentioned that one of the primary reasons for the A-B choice is that it uses a communications format named ‘CIP’, and its internal memory configuration is entirely driven by TAGNames.
In tne ControlLogix platform, you do not do programming or configuration by having to remember or know things like “... ‘B-703:R-E5<OTB>T-1’ is wired to terminal IW102... (That’s Building 703, Room E5, Optical Testing Lab, Temperature 1)” .
Re: Remote I/O David Dudley
Prev: RE: New home for asyn Mark Rivers
Next: mbboDirect problem Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Remote I/O David Dudley
Next: Re: Remote I/O David Dudley
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
