leige wrote:
Recently we experienced a trouble in one IOC, it does not respond to telnet, but it says alive if I ping it. New CA connections can not be setup to it, but those CAs which have been setup can work normally. We got lots of warnings on this IOC's console,
-> 0xc26180 (CA_UDP): arpresolve: can't allocate llinfo0xc26180 (CA_UDP): arpres
olve: can't allocate llinfo0xc26180 (CA_UDP): arpresolve: can't allocate llinfo0
"arpresolve: can't allocate llinfo" usually indicates an incorrect
netmask (or may be a bad route). Your IOC is sending out an arp
request to map an IP address to a MAC address on the local network
and is getting back a response which appears to not be local.
Check the netmask on the IOC (ifShow). If that looks OK, check the
routing table (routeShow) and the arp table (arptabShow). If that
doesn't show you the problem, try snooping the network to see
which IP address it is looking up and which host on the network is
responding.
Steven Hartman
[email protected] || 865-466-6473
- procServ softIOC server - V2.5.0 released Ralph Lange
- arpresolve: can't allocate llinfo0xc26180 (CA_UDP): leige
Re: edm installation problems Julio Calvo Pinto
support for keithley 2612 source meter David Kline
<2009>
Re: procServ softIOC server - V2.5.0 released Ralph Lange
<2009>
