Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: File I/O from genSub Process function
To: "Bruce Hill" <bhill@slac.stanford.edu>, "Techtalk" <tech-talk@aps.anl.gov>
Date: Fri, 30 Oct 2009 13:53:27 -1000
Hi Bruce,
I do file I/O from GenSub process functions without any problem. We are
using VxWorks, not RTEMs, although I am not sure if or why that would
make a difference.
Erik
-----Original Message-----
[mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Bruce Hill
Sent: Friday, October 30, 2009 1:42 PM
To: Techtalk
Subject: File I/O from genSub Process function
I have a genSub I've setup to run test code on my IOC, and I'm getting
errors when I try to read the test set data files.    This is an RTEMS
4.7.1 based
IOC accessing an NFS mounted filesystem.     I'm able to read the same
files from a genSub Init function, but not from the Process function.
I can also read these files if I initiate the test from the Cexp shell
on the RTEMS console.
Is there something about how the Process functions are called that would
preclude file I/O?
Thanks!
- Bruce Hill
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA  94025
File I/O from genSub Process function Bruce Hill
Prev: File I/O from genSub Process function Bruce Hill
Next: Re: File I/O from genSub Process function Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
