Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: File I/O from genSub Process function
To: Techtalk <tech-talk@aps.anl.gov>
Date: Fri, 30 Oct 2009 16:41:33 -0700
I have a genSub I've setup to run test code on my IOC, and I'm getting
errors when I try to read the test set data files. This is an RTEMS 4.7.1 based
IOC accessing an NFS mounted filesystem.     I'm able to read the same
files from a genSub Init function, but not from the Process function.
I can also read these files if I initiate the test from the Cexp shell on the RTEMS
console.
Is there something about how the Process functions are called that would
preclude file I/O?
Thanks!
- Bruce Hill
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA  94025
RE: File I/O from genSub Process function Erik Johansson
Re: File I/O from genSub Process function Andrew Johnson
Re: File I/O from genSub Process function Till Straumann
Prev: Re: devLibOSD.c for Linux Graham Waters
Next: RE: File I/O from genSub Process function Erik Johansson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: EPICS BACnet Support Marty Kraimer
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
