Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: asyn messages
To: "Benjamin Franksen" <benjamin.franksen@bessy.de>, <tech-talk@aps.anl.gov>
Date: Fri, 16 Oct 2009 08:08:21 -0500
You can turn off the error messages completely with
asynSetTraceMask("L3", 0)
I don't think you can only print connection status change messages.
Right now the asyn trace mask bits are:
#define ASYN_TRACE_ERROR     0x0001
#define ASYN_TRACEIO_DEVICE  0x0002
#define ASYN_TRACEIO_FILTER  0x0004
#define ASYN_TRACEIO_DRIVER  0x0008
#define ASYN_TRACE_FLOW      0x0010
I have been thinking that it would be good to add
ASYN_TRACE_WARNING
which would print messages for conditions that are less severe than ASYN_TRACE_ERROR, but still not "normal" which is when ASYN_TRACE_FLOW should print.
I don't think that would solve your problem though, since presumably you would like to see a message on reconnect, which would not be characterized as an error or warning.
From: tech-talk-bounces@aps.anl.gov on behalf of Benjamin Franksen
Sent: Fri 10/16/2009 7:34 AM
To: tech-talk@aps.anl.gov
Subject: asyn messages
The log files of some of our IOCs are spammed with failed reconnect messages
like this:
[Fri Oct 16 09:30:15 2009]2009/10/16 09:30:15.139
asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
[Fri Oct 16 09:30:21 2009]2009/10/16 09:30:21.147 L3 vxiConnectPort error
gpibc1cp.mlscs.bessy.de: RPC: Remote system error - No route to host
[Fri Oct 16 09:30:21 2009]2009/10/16 09:30:21.147  L3 -1 autoConnect could
not connect
[Fri Oct 16 09:30:27 2009]2009/10/16 09:30:27.156 L3 vxiConnectPort error
whenever e.g. a gpib box is turned off.
Is there a way to tell asyn to shut up and output mesasages only when
connection status changes?
Cheers
Ben
asyn messages Benjamin Franksen
Prev: asyn messages Benjamin Franksen
Next: Re: StripTool build errors: SDDS.h? Janet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017
Next: Incorrect get_precision Schoeneburg, Bernd
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
