1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: StripTool build errors: SDDS.h?
To: Carl Schumann <[email protected]>
Cc: "Denise S. Finstrom" <[email protected]>, [email protected]
Date: Fri, 16 Oct 2009 09:10:26 -0500
StripTool has an option to output plot data in SDDS format. This option, USD_SDDS, is set in the Makefile and the default for it is YES. If you don't have SDDS, you can set USE_SDDS to NO.
Janet
Carl Schumann wrote:
Denise, et. al.,
I am trying to build StripTool in my home directory, but get a messing header file, SDDS.h, error. Did you see this error when you built StripTool? (SDDS appears to be another EPICS extension, but does not appear to be installed on the clx machines either. Yet you built StripTool at some point. I attempting the same most current version you have for production.)
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -DUSE_MOTIF -DUSE_CLUES -DUSE_XPM -DUSE_XMU -DUSE_SDDS -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -DNO_ARCHIVER_CALL -m32 -g -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../base/include/os/Linux -I../../../../base/include -I../../../include -I/usr/include -I/usr/include/X11 -I/usr/include/X11 -I/usr/include/X11 ../StripDataSource.c
../StripDataSource.c:69:18: error: SDDS.h: No such file or directory
Carl
StripTool build errors: SDDS.h? Carl Schumann
Prev: RE: asyn messages Mark Rivers
Next: Incorrect get_precision Schoeneburg, Bernd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: StripTool build errors: SDDS.h? Carl Schumann
Next: asyn messages Benjamin Franksen
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
