1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: problem using epid record
To: "Maurizio Montis" <[email protected]>, <[email protected]>
Date: Wed, 26 Aug 2009 11:39:17 +0200
I'm also a user of the epid record (which by the way is *great*). However, I use it here at PSI within our 'custom' environment.
In the Epics release R3.14.8.2 it is located in the 'SynApps' package, which you should include.
I would be happy to share any other information on the usage (from my experience), if you would like.
Trivan
Dr. Trivan Pal
[email protected]
+41 56 310 4558
PSI
Switzerland
From: [email protected] on behalf of Maurizio Montis
Sent: Wed 8/26/2009 11:22 AM
To: [email protected]
Subject: problem using epid record
i'm looking for to use the epid record to control an High Voltage
Power Supply but i'm in trouble: i'm trying to compile my ioc but i
have this kind of error:
make[3]: *** No rule to make target
`../../../lib/linux-x86//libepidRecord.a', needed by `testPID'.  Stop.
I've setted the Makefile in src directory specifing:
1) testPID_DBD += epidRecord.dbd
2) testPID_LIBS += epidRecord
3) testPID_LIBS += devEpidSoft
where is my mastake? thanks a lot for any suggestions.
Maurizio M.
Re: problem using epid record Maurizio Montis
Prev: Re: How to let Hytec8401ADC works on interrupt way ? graham
Next: Re: problem using epid record Maurizio Montis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: problem using epid record Maurizio Montis
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
