Hi Liu,
You do not need to change / set any switches on the hardware, the
setup is software contolled (assuming you are using our 8002
carrier).Your VME64x crate should not need any configuing for
interrupt operation from your carrier.
I'm on an exhibition stand at FEL09 and several staff are on holiday
at the moment. We will send you a direct email reponse shortly.
We now have a tested Asyn driver for the 8401 available that uses "I/O
Intr" mode tested up to 20Khz.
Graham Cross
Hytec Electronics Ltd.
This message was sent using IMP, the Internet Messaging Program.
- How to let Hytec8401ADC works on interrupt way ? liuping
problem using epid record Maurizio Montis
RE: problem using epid record Pal Trivan
<2009>
re: How to let Hytec8401ADC works on interrupt way ? liuping
<2009>
ANJ, 31 Jan 2014 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
