1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: driver support initiialization
To: "Patrick Thomas" <[email protected]>, <[email protected]>
Date: Wed, 22 Jul 2009 08:26:38 -0500
If you are writing a new driver I would encourage you to look at the new
C++ base class called asynPortDriver that was added to asyn R4-11.
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-11a/asynPortDriver.htm
l
This base class makes it very simple to write a new device driver of any
type (synchronous or asynchronous, VME, serial, with or without
interrupts, etc.)  It supports the standard asyn device support for most
common EPICS records.  There is an example driver provided in the asyn
distribution.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Patrick Thomas
Sent: Tuesday, July 21, 2009 10:51 PM
To: [email protected]
Subject: driver support initiialization
I have created a device driver to interface with a serial to ethernet
adpater, and I was just wondering if it is possible to send the IP
address and port to the driver at initialization, say through an entry
in the st.cmd file?
Thank you,
Patrick
Asyn Driver support for Hytec 8401 ADC Graham Cross
driver support initiialization Patrick Thomas
Prev: Re: labview w/ CA Wesley Moore
Next: Asyn Driver support for Hytec 8401 ADC Graham Cross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: driver support initiialization Matthieu Bec
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
