This is the fix that makes things work for me. In the specific Makefile
I just ensure that all backward slashes are substituted with forward
ones in the path that fullPathName.pl generates.
As different installations of perl seems to produce different results I
think it's is probably a reasonable solution to just force forward
slashes in this case where the specific problem is that the path is
being passed on to C and used as a string...
W:\work\up45\R3.14.10\base>svn diff src\softIoc\Makefile
Index: src/softIoc/Makefile
--- src/softIoc/Makefile (revision 33692)
+++ src/softIoc/Makefile (working copy)
@@ -18,7 +18,7 @@
softIoc_DBD += base.dbd
softIoc_DBD += system.dbd
-ABS_INSTALL_DIR = $(shell $(PERL) $(TOOLS)/fullPathName.pl
$(INSTALL_LOCATION))
+ABS_INSTALL_DIR = $(subst \,/,$(shell $(PERL) $(TOOLS)/fullPathName.pl
$(INSTALL_LOCATION)))
USR_CXXFLAGS += -DEPICS_BASE=$(ABS_INSTALL_DIR)
softIoc_SRCS += softIoc_registerRecordDeviceDriver.cpp
Cheers,
Ulrik
-----Original Message-----
[mailto:[email protected]] On Behalf Of Rees, NP (Nick)
Sent: 17 July 2009 09:24
To: [email protected]
Subject: RE: Escaped strings from fullPathName.pl
I can get both forward and backward slashes.
C:\home\epics\R3.14.7\base\configure\tools>fullPathName.pl ..\..
C:/home/epics/R3.14.7/base
C:\home\epics\R3.14.7\base\configure\tools>fullPathName.pl ../..
C:\home\epics\R3.14.7\base\configure\tools>fullPathName.pl c:\home
c:\home C:\home\epics\R3.14.7\base\configure\tools>fullPathName.pl
c:/home c:/home C:\home\epics\R3.14.7\base\configure\tools>
C:\home\npr78>perl -v
This is perl, v5.8.7 built for MSWin32-x86-multi-thread (with 14
registered patches, see perl -V for more detail)
Copyright 1987-2005, Larry Wall
Binary build 815 [211909] provided by ActiveState
http://www.ActiveState.com ActiveState is a division of Sophos.
Built Nov 2 2005 08:44:52
Looks like perl is not completely consistent.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
Scanned by iCritical.
- Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
- RE: Escaped strings from fullPathName.pl Mark Rivers
- RE: Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
- RE: Escaped strings from fullPathName.pl Rees, NP (Nick)
Libera EPICS driver 2.00 release Michael Abbott
<2009>
Re: Escaped strings from fullPathName.pl Andrew Johnson
<2009>
