1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: subArray processing
To: Hinko Kocevar <[email protected]>
Cc: [email protected]
Date: Wed, 03 Jun 2009 09:55:50 -0500
On 6/3/09 8:23 AM, Hinko Kocevar wrote:
>>> Hello,
>>> I'm trying to use subArray record type to display each array element at
>>> index 0 .. n (n == 10; my case) in a separate PV.
>> For your subArray records, use . . .
>>   field(MALM,"16") # number of elements of the waveform input
>>   field(NELM,"1")  # number elements for desired subArray
>> The subArray needs to allocate enough storage for MALM elements to  hold
>> the whole INP waveform, but you only want NELM elements for the subArray
>> itself.
> If I change subArray records the way you described it does not change
> the output of the monitor to display only one value. The output is the
> same as in the case I've described in previous mail (not desired to have
> trailing zeros).
Hi, Hinko.
I agree with Steven's advice that you should use MALM=16 for your
subArray records.
What version of EPICS are you using?  There is a known problem with the
subArray record before EPICS 3.14.10.  Could you check the value of
"$(DEVICE)B.INDX" during your test?  Has it been set to 0 even though
you specified a value of 1?  If so, you may be running into the problem
reported in the following Tech-Talk message:
  http://www.aps.anl.gov/epics/tech-talk/2007/msg01432.php
Lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
Re: subArray processing Hinko Kocevar
Re: subArray processing Steven M. Hartman
Prev: Re: subArray processing Hinko Kocevar
Next: Re: subArray processing Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: subArray processing Hinko Kocevar
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
