1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: subArray processing
To: "Steven M. Hartman" <[email protected]>
Cc: [email protected]
Date: Wed, 03 Jun 2009 15:23:26 +0200
Steven M. Hartman wrote:
> Hinko Kocevar wrote:
>> Hello,
>> I'm trying to use subArray record type to display each array element at
>> index 0 .. n (n == 10; my case) in a separate PV.
> For your subArray records, use . . .
>   field(MALM,"16") # number of elements of the waveform input
>   field(NELM,"1")  # number elements for desired subArray
> The subArray needs to allocate enough storage for MALM elements to  hold
> the whole INP waveform, but you only want NELM elements for the subArray
> itself.
If I change subArray records the way you described it does not change
the output of the monitor to display only one value. The output is the
same as in the case I've described in previous mail (not desired to have
trailing zeros).
Best regards,
Hinko
Hinko Kocevar
Technical support engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
Re: subArray processing J. Lewis Muir
subArray processing Hinko Kocevar
Re: subArray processing Steven M. Hartman
Prev: Re: subArray processing Steven M. Hartman
Next: Re: subArray processing J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
