1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ai record with dtyp of "raw soft channel"
To: Patrick Thomas <[email protected]>
Cc: [email protected]
Date: Fri, 03 Apr 2009 14:39:46 +0200
Hi Patrik,
I tried it and it works. You did not try to set the INP link to the RVAL field of the other record (which is not Raw Soft Channel), did you?
Also keep in mind that the RVAL field is an integer. Thus pointing the INP to a double field will round the value (eventually to 0).
Dirk
Patrick Thomas wrote:
I'm trying to use an ai record to obtain the value of a channel from a record on another IOC. I have the INP field set to "(name of field on other IOC) CP"; When I specify the DTYP as Soft Channel, it reads the value and updates as it changes. But when I set the DTYP to Raw Soft Channel so that I can do conversion on it, both the RVAL and the VAL fields stay a constant 0.
Thank you,
Patrick
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
ai record with dtyp of "raw soft channel" Patrick Thomas
Prev: Re: Asyn changes Eric Norum
Next: Re: EPICS at exit memory leak Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: ai record with dtyp of "raw soft channel" Patrick Thomas
Next: Re: ai record with dtyp of "raw soft channel" Ralph Lange
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
