Hi Pierrick,
You can use a calcout, but not the way you are doing it. You are not actually using the output of the calcout to write the values to the .HIHI field, you are trying to use the ai record to read the values from the calcout:
record(ai, "$(user):Q1ReadCurrent") {
field(HIHI, "$(user):calcQ1I_HiHi.VAL")
field(HIGH, "$(user):calcQ1I_High.VAL")
That won't work, because the HIHI etc. fields are not input links.
You need to do something like the following:
record(calcout, "$(user):calcQ1I_LoLo") {
field(DESC, "Q1 I Min Major limit")
field(PREC, "3")
field(INPA, "$(user):Q1SetCurrent.VAL NPP NMS")
field(INPB, "$(user):ILimMajor.VAL NPP NMS")
field(CALC, "A-A*B")
--> field(OUT, "$(user):Q1ReadCurrent.HIHI NPP NMS")
You might also want to change under what conditions the calcout writes its output: only on change, etc.
From: [email protected] on behalf of Pierrick Hanlet
Sent: Thu 3/19/2009 6:10 AM
To: [email protected]
Subject: Alarm Limits
Can one use the output of a calc or a calcout routine to set values for HIHI, HIGH,
LOW, and LOLO? When I load my database, I always get errors in these lines. Is
there some sort of special incantation that I must do?
Here's what I have. I've used camonitor to check that all of the records leading
up to and including the calc records work as expected. For the calcout routines,
I have a value between 0<= VAL <=1 for ILimMajor and ILimMinor. The calcout
records appear to do what I want them to do:
record(calcout, "$(user):calcQ1I_HiHi") {
field(DESC, "Q1 I Max Major limit")
field(PREC, "3")
field(CALC, "A+(A*B)")
record(calcout, "$(user):calcQ1I_High") {
field(DESC, "Q1 I Max Minor limit")
field(PREC, "3")
field(INPB, "$(user):ILimMinor.VAL NPP NMS")
field(CALC, "A+A*B")
record(calcout, "$(user):calcQ1I_Low") {
field(DESC, "Q1 I Min Minor limit")
field(PREC, "3")
field(PREC, "3")
field(DESC, "Q1 Magnet Readback Current")
field(PREC, "3")
field(INP, "$(user):rampQ1Current.VAL NPP NMS")
field(EGUF, "10")
field(EGU, "A")
field(HOPR, "2000")
field(LOPR, "0")
field(LOW, "$(user):calcQ1I_Low.VAL")
field(LOLO, "$(user):calcQ1I_LoLo.VAL")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LLSV, "MAJOR")
field(FLNK, "$(user):Q1RampCurrent.PROC")
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
